I have just had to re-install W2K on my WD PC and have a problem now with Startwatch getting connection refused on the VirtualVP TCP/IP port when it tries to see if VVP is up and running. I’ve checked on settings and that the PC has the correct IP address after re-install and all seems fine. Anyone any ideas?
Edit: After the re-install I forgot to check the VVP setup correctly, now that is setup OK startwatch works fine.
