Resetting data
I am a newbie, do not yet have a weather station so am running “stationless”. Have been fine tuning the offsets to get barometer recording accurately (not quite there). When I reset Daily Extreme Values and Selected All Time Record Values they do not clear, staying the same as the first operating day. The metar readings are being received and flash on the screen when the updates are received. Anyone able to assist?
it most likely I have not set a flag so that the all time records are updated by a metar update of WD’s data
or something like that
I will check up on that and let you know
Appreciated. Thanks.
try a new 9.96a for a test drive
it might improve things
Thanks greatly for the update. It has fixed the min/max temperature but the average windspeed, current windspeed, maximum gust last hour, maximum average all read 13.0kph and have done so for the past three days since I downloaded 9.96d and now with 9.96a. The metar provides a different wind speed. Appreciate this problem is related to not having weather station connected but is it fixable?
what metar are you using?
I will do some testing, and get it working
The metar being used is YSSY Sydney Airport. Monitoring since downloading 9.96a shows that the metar details have not updated since closing the lid of the laptop last night. Have restarted WD as well as computer. Using a laptop with Windows XP. Apologies for these problems. I really like the software and intend purchasing but will not be getting a weather station straight away. Strange things are also happening with the barometer - it is manually set then jumps between 1083, 1072 and 1069 on the display but on the real time graph it jumps between 1021 and 1010. Need to set the wind direction gauge manually also.
Have just found another Metar to use - OBSH Sydney Observatory but being unable to receive metars I am unable to check out the data.
Cheers
i will give them a whirl today…
it will be something to do with the barometer
what do you have set as yoru barometer adjust, under setup, barometer offsets and rainfall?
also, email me your wdisplay.ini file from c:\windows or c:\winnt and i will check out your settings
([email protected])
thanks
Here is WDISPLAY.INI. A couple of things have happened since upgrading to 9.96a.
  • Graphs are not plotting with exception of wind direction (which I set manually) and humidity (unwavering on 63% rain or shine)
  • The barometer on display reads 1071 but on graph 1021 (correct) - this resulted from entering 1021 manually. Barometer seems to have settled down so I am trying it with an offset of 0 just to see if it will correct the 1071 display. I have tried almost every offset number to no avail. (Trying to understand the whole offset issue.)
  • Unable to set longitude but latitude ok.
  • Appears to poll but has not successfully updated the Metar since prior 9.96a upgrade.
  • Min/Max Temperature set on 16 - actual 17-27.
  • Wind average gust/speed wavers between 12.9 and 13 not reflecting actual but when metar info received flashes 40 then back to “default” .
With 9.96d when metar information was received it flashed on the display then disappeared.
[starttime]
time=5:13:46 AM
[startdate]
date=7/11/2003
[Program location]
location=C:\Documents and Settings\Lesley
[WM918 rain gauge]
new setting=1.0
[Language]
Selected=English
Done new selection=yes
[Reset times]
option=9am
[Max wind gauge]
number=0
[Graph speed lift]
number=0
[New year rain reset time]
number=1
[New daily reset time]
number=7
rain number=7
[Height above sea level]
value=0
[Main graph temp lift factor]
value=10
[New units]
icon temp=yes
icon wind=no
rain dp=no
show windrun=no
use chill gust=yes
cloud in metres=yes
use qfe=no
rain dp mm=no
wind=kmh
webwind=kmh
temp=celsius
webtemp=celsius
rain=mm
webrain=mm
baro=hpa
webbaro=hpa
bftdial=no
bftsummary=no
web different=no
logfile=metric
date=metric
webdate=metric
[New windchill]
use=no
[Daily high average]
todayrain=0.0 mm
number2time=4:12 PM
number2=12.9 kmh N
raintime=07:00 AM
[Weather Station Type]
Name=stationless
Davis vp speed=9600
univeral file=C:\Documents and Settings\Lesley
climatronics speed=9600
UWS3000ws=metric units
[Auto start]
option=no
[Start hidden]
flag=true
[Start minimised]
flag=false
[Davis download]
hour=6
minute=44
day=7
month=11
year=2003
[custom view]
custtag1 vis=yes
custtag2 vis=yes
custtag3 vis=yes
custtag4 vis=yes
custtag5 vis=yes
custtag6 vis=yes
custtag7 vis=yes
custtag8 vis=yes
custtag9 vis=yes
custtag10 vis=yes
custtag11 vis=yes
gustdial vis=yes
avdial vis=yes
dirdial vis=yes
outdoortempdial vis=yes
raintank vis=yes
stations vis=yes
value1 vis=yes
value2 vis=yes
baroplot vis=yes
temphumplot vis=yes
image1 vis=yes
image2 vis=yes
imagescreen vis=yes
realgraph vis=yes
web vis=yes
imageback vis=yes
last custtag1 left=224
last custtag1 top=272
last custtag2 left=224
last custtag2 top=296
last custtag3 left=222
last custtag3 top=322
last custtag4 left=222
last custtag4 top=347
last custtag5 left=221
last custtag5 top=372
last custtag6 left=361
last custtag6 top=271
last custtag7 left=360
last custtag7 top=296
last custtag8 left=359
last custtag8 top=322
last custtag9 left=359
last custtag9 top=347
last custtag10 left=358
last custtag10 top=371
last custtag11 left=358
last custtag11 top=393
last window width=1017
last window height=731
last window left=5
last window top=9
last gust left=33
last gust top=15
last av left=433
last av top=23
last dir left=261
last dir top=52
last temp left=80
last temp top=215
last rain left=36
last rain top=197
last value1 left=224
last value1 top=216
last value2 left=360
last value2 top=216
last baroplot left=561
last baroplot top=213
last temphumplot left=560
last temphumplot top=470
last image1 left=72
last image1 top=433
last image2 left=424
last image2 top=481
last real left=560
last real top=728
last main graph left=64
last main graph top=504
last web left=24
last web top=1193
last stations left=5
last stations top=1008
last gust width=184
last gust height=154
last av width=184
last av height=154
last dir width=124
last dir height=109
last temp width=86
last temp height=171
last rain width=25
last rain height=98
last value1 width=67
last value1 height=20
last value2 width=67
last value2 height=20
last baroplot width=424
last baroplot height=259
last temphumplot width=424
last temphumplot height=251
last image1 width=259
last image1 height=61
last image2 width=120
last image2 height=237
last real width=401
last real height=282
last main graph width=289
last main graph height=298
last web width=513
last web height=433
[Meso count]
value=1
[New maximum temperature]
value=16.0
[New minimum temperature]
value=16.0
[Vp high soil]
value=-100.0
[Vp low soil]
value=100.0
[Vp high leaf]
value=-100.0
[Vp low leaf]
value=100.0
[wunderground time delay]
hamweather=-114
wunderground=-24
[First rain since start]
flag=no
[High tide]
hour=3
hour2=15
minute=31
minute2=36
[Evapo]
reading=0
[Low tide]
hour=8
hour2=22
minute=55
minute2=33
[Daily solar]
value=51105
month et value=0
[Daily solar count]
value=7503
yesterday et=0
[Old indoor]
temp=0
hum=0
[Daily wind run]
value=512
month value=2740
year value=2740
[Dallas lightening time]
last time=
[Dallas rain]
last count=0
[Graph setup]
temp adjust scale=-15
[Sunshine hours]
month=0
year=0
day=0
[Frost duration]
value=0
[Lightening count]
value=0
noon value=0
month value=0
year value=0
[Yesterday rain]
value= 0
[Maximum daily gust]
value=70
[Maximum hour gust]
value=70
[Indoor temp new2]
max= 0
min= 0
[Indoor hum new2]
max=0
min=1010
[Dallas hum temp]
max=-1000
min=1000
[Dallas hum temp2]
max=-1000
min=1000
[Dallas extra hum1]
max hum= 0
min hum=1000
[Dallas extra hum2]
max hum= 0
min hum=1000
[Dallas extra hum3]
max hum= 0
min hum=1000
[Dallas extra hum4]
max hum= 0
min hum=1000
[Dallas extra hum5]
max hum= 0
min hum=1000
[Dallas extra hum6]
max hum= 0
min hum=1000
[Dallas extra hum7]
max hum= 0
min hum= 0
[Dallas extra hum8]
max hum= 0
min hum=1000
[Dallas extra hum9]
max hum= 0
min hum=1000
[Record monthly high temp]
oct=0
oct year=2003
oct day=21
nov=160
nov year=2003
nov day=1
jan=
jan year=2003
[Record monthly low temp]
oct=0
oct year=2003
oct day=21
nov=0
dec=
dec year=2003
[Coldest night]
value=37170
count=177
[Warmest day]
value=523220
count=6210
[Energy wind]
0=4974
1=0
2=0
3=0
4=2345
5=0
6=0
7=0
8=0
9=0
10=1
11=0
12=0
13=0
14=0
15=0
16=0
17=0
18=0
19=0
20=0
21=0
22=0
23=0
24=0
25=0
start date=22/10/2003
[Energy wind year]
0=4974
1=0
2=0
3=0
4=2345
5=0
6=0
7=0
8=0
9=0
10=1
11=0
12=0
13=0
14=0
15=0
16=0
17=0
18=0
19=0
20=0
21=0
22=0
23=0
24=0
25=0
[Days with no rain]
number=0
current rain duration=0
[Daily high pressure]
number2=1077.1 hPa
number2time=06:13 AM
number=10771
[Daily low pressure]
number2=1070.3 hPa
number2time=07:03 AM
number=10703
[Daily low windchill]
number2=13.0
thanks
i also need your registry settings for wd:
go to action, back up registry, and click on backup, then email me the file wdisplayfp.reg from the folder databackup
(email to [email protected])
i tested with the sydney metar, and the grpah etc and on screen info updated OK…for me…but the metar actual data was not updating very often
Brian, you have fixed all the problems with the turning off of the client switch and unchecking clientraw.txt. WD is working beautifully. Must thank you for your patience and support. You are a master.
Surfside
Thanks to the masterful assistance of Brian, my stationless WD is
working beautifully. On Brian’s advice the Server Enabled switch
was engaged and clientraw.txt was unchecked. Everything is
history since and WD is great. Thank you again Brian, you are
appreciated. Enjoy your space with the wife, kids, cows, fishing
and whatever you decide to do.
From a much appreciative user.
