So you need a funnel of 15.81 cm radius. Or 31.62 cm diameter.
Edit: just a note on this. Take into account that you are letting so much more water inside, so the tipping mechanism can be easily overflown. The accuracy you’re looking for may become a big error.
Just my personal opinion but I think that’s an unreasonable decrease in tip size. I wouldn’t be trying to push that amount of water through that coffee mug sized OS rain gauge.
Sorry Breitling it was the tip size i was on about, its cause its in the rain offsets is why
i kept calling it the offset :oops:
The internal Diameter is now exactly 31cm thanks Breitling…
i cut the darn thing down too much, so much for the 0.1mm, it cant be too far off though
I just want to give it a try Niko, see how it goes, if its too much then i will just remove it
It looks a bit ott i mist admit cause each stage i have made it bigger i just kept the older
one attached so it had the area for the new one to fit into, to its a 3 stage tower now lol
I also had to use a biggish flower container, finding a funnel was proving difficult for the size
wanted, so i went for something much bigger and cut it down…I aint attached it to the bucket
yet so no pics at present sorry, to be honest i dont really want to show it off either :oops:
0.1 is going to give you quite a few problems , as soon as you get moderate rain it will overwhelm the sensor
and give you incorrect rain readings
the lowest I have managed to get 0.25 tipping so far this is give me good results I would have fought there was a standard for the minimum tipping of most rain gauges Davies 0.2
I will be interested to see how you go on with this please send me some data back when you have some heavy rain
I would also put out a traditional manual rain gauge so you can compare results
If it does cause any issues then i will just remove it again, its was stuck down with
hot glue so thinners will easily dissolve the glue, dont care about the addons if they
melt a little i can just sand them down
I will certainly let you know how it goes, theres a manual weather station in Lidl later this week
could be now actually, i cant remember and i will get that to compare with
I thought davis was 0.1mm? oh well lol but i did read on here somewhere that someone did modify
to 0.1mm and it was running ok, just cant remember where i read it now…
I dont think its gonna be quite 0.1mm anyway as i cut it down too much #-o
Thanks lol, you aint seen the image yet, attached below :oops:
A test pour never works out, i always end up doing too fast
But i will report the findings thats for sure…
Please dont laff, at least the top looks pretty :lol:
Looking at it i can see it getting blown off either Friday or Sunday :? :roll:
You need a known start point. And that is the original Oregon resolution. A tip based on a 10 cm diameter area (78.53 cm2) is 1 mm. Use these data as your “old” data with the second Niko’s calculator. The first one is not valid.
