Author Topic: Average Wind Dial not working  (Read 4995 times)
Offline jraubal
    • http://www.raubal.org
« on: October 25, 2003, 05:38:50 PM »
Just noticed that the average wind dial shows no value, even though there has been wind, and the text suggests an average wind...
Not sure if this is new or not....
on the topic of title bars on images, the 'Extra Daily High/Low Weather Parameters' is the only one where the bar is persistently there, the others (summary.png especially) only do it on either start-up or a manual update (but not all the time) – hmm could make it hard to track down…
http://www.jraubal.dial.pipex.com/wd/Puckeridge.html
(site updated at 9, 12, 15 and 18 hours GMT)
Hope that helps
Johan
Oregon Scientific 918
Offline jraubal
Not quite what I had in mind...
« Reply #1 on: October 27, 2003, 08:06:05 AM »
Well, could some kind moderator of this forum take pitty on my and remove this topic!  This should have been posted as a reply in the thread for the software....
My mistake!
rgds
Johan
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #2 on: November 05, 2003, 01:37:57 AM »
is it still a problem, the wind speed?
the problem with the daily high/low is that i think it does it 2x in the update routine
i think
i have nearly finished putting in the cjustom screen and mesomap
i just want to add auto scale graphs back, and extra sensor dials
Offline jraubal
« Reply #3 on: November 06, 2003, 12:10:47 PM »
Yup,
Not getting an average at all in the graph of the dials (same for the real time stuff - but it is essentially the same graphing bit of software I guess so that is no surprise)
I also noticed that the it does not record any of the daily extremese either, they are always set to daily high - -50C  and daily low - +50C.
Thanks for all the hard work!
Can also happlily state that beside one of the graph images being rendered off screen (after a day or so of running) , it is very stable!
regards
Johan
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #4 on: November 06, 2003, 04:10:17 PM »
i am still not sure where you are in the program re the wind average
do you have it enabled, under graph setup, plot the lines...
what weather station type?
daily reset:
any thing under view, program error log after it has supposed to have done it?
Offline jraubal
« Reply #5 on: November 07, 2003, 07:37:06 AM »
Brian,
Well, the station is a 928, and the pictures are what is on the web page, or if you click on the dials in the program.  (gives you same set of dials but in realtime mode) - the program does generate a text value for the average - which is what got me started on why there was no average value display in the *dial*.  ...I think I might have confused you by going on about graphs, it should of course be dial...  Better?
As soon as I get to the computer I will look at the logs and post anything relevant re:daily averages.
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #6 on: November 07, 2003, 07:53:52 AM »
ok, found it....
only occured if you were using knots
it will be fixed for the next linux version I will release
Offline LaneLester
  • Georgia, USA
    • The Web Doctor
« Reply #7 on: December 16, 2003, 01:19:33 PM »
Quote from: windy
That would be a nice Christmas present. :D
