Bob, Yep. Saw Dave A’s first posts about it last night. It’s unfortunate it came to this, but the upside is that Dave H now seems to be trying to address the problems finally. And the other positive bit, if you’ve continued reading this morning, is that it’s come out that the old Tier-2 servers ARE still accepting packets, so that’s some good news.
Brian, Would it be possible to add an option to the CWOP upload settings to allow us to select an “every X minutes” upload option where X would be an odd value like 8, 9 or 11? Right now we have the option of every 5, 10, 15, 30 etc minutes, but it sounds like such “boundaries” can lead to server overloads where as an odd upload interval would be a constantly changing time as the day progresses, thus reducing those “hot spots”. It sounds like this might help address what sounds like one of the larger complaints the server admins have.
Hmmm … I’m running 10.37h … but only “Build 05”. I guess I need to look at more than just the major version name. This would help to some extent, but it’ll still be at the “same time” every hour, where as if we could set it to upload every 9 or 11 minutes we’d more effectively randomize the uploads over the course of a day.
Also, I’m not quite sure when this was requested, but when I started, we were told to upload every 15 minutes. Apparently CWOP (at request of NWS?) started asking folks to upload every 5 to 10 minutes in the not too distant past. Hence the suggestion for the option to upload every 9 or 11 minutes.
I never changed from every 15 minutes and I am inclined to stay at that but change from using 00 - 15 - 30 - 45 to use an offset of “3” as my station ID ends with 3…
niko, Thank you for that pointer! I haven’t had the time to watch the forums much lately and missed that one.
hmmm … I have two CWOP ID’s … AR651 and N1PRS-9. FindU shows me as N1PRS-9. MesoWest shows AR651 as my “ID” and N1PRS-9 as my “Name”. So. Should I upload with an offset of 1 or 9?
FWIW, the current “build” of v10.37h is 26. wow, my version sure was old in comparison!
rotate.aprs.net only rotates to two servers right now and using cwop.aprs.net would allow for quick moving of weather data to a separate server or network in the future if needed…
Note that to enable to offset you have to select the minute offset in your WD CWOP setup screen and then reset the time interval, which is officially recommended at every 10 minutes http://www.wxqa.com/news.html
Jan 16, 2008 Date
(I have been using 15 since day one and ain’t changing that now LOL)
Just as a follow-up since I switched both the time of the uploads (yeah I finally ungraded) and started using cwop.aprs.net I have recorded data every 15 minutes where before some hours only two got through and sometimes 3 but never all 4 each hour (since the upheaval)
Bob, After switching to cwop.aprs.net last night … doesn’t look like I missed a single submission.
Jim, How long had it been since you’d restarted your WX PC? Or at least WD? I tend to reboot every 4-6 weeks (primarily to capture MS patches. ), but I was able to change my CWOP targets multiple times yesterday w/o a single restart.
Brian, Have you had any recent communincations with Dave Anderson or Dave Helms from CWOP? It sounds like cwop.aprs.net should be the new default, but I’m on the outside looking in and would hate to misguide you. Dave Anderson, yesterday, published a white paper on recommended changes to the CWOP network it bullet #1 does state that client software should connect to port 14580 of DNS alias cwop.aprs.net. It might be a good idea to touch base with them.
I am forwarding you an email from the CWOP Quality Control List that to me appears to have both Dave Anderson and Dave Helms agreeing to start switching CWOP traffic to use cwop.aprs.net
I have emailed and heard back from Dave Anderson.
(as I have never heard from Dave Helms about this).
And so the next full update of WD (i.e with the new ftupd.exe) will use the cwop.aprs.net by default.
Luckily WD is not one of the software that has been causing a problem, from what I have heard back.
Just for anyone reading this, you do not have to wait for an upgrade to WD to make the change to cwop.aprs.net which can be done in your CWOP setup screen…
Brian, Considering how they were describing they wanted the clients to work, unless someone running WD was sending ever minute, I didn’t suspect WD as being “a problem child” at all. But it is good to hear positive feedback of that. By the way, it’s been at least a year since “I’ve had your ear” … just wanted to reiterate to you what I sent to the CWOP server folk - Thank you for your time and efforts with Weather Display! Yes, I’ve paid for it and you’re “just a businessman”, but … you do put alot of effort into this program and you do listen to your customers, so … Thank you!
all, As Bob indicates, you don’t have to wait for the new WD update with the new defaults, you can set your current installation to use the new alias by simply setting “cwop.aprs.net” as your primary CWOP upload target. Make sure you set the “port” to 14580.
This just came through from the CWOP QC Mail List…
from [email protected]
reply-to Discussion of weather data quality issues ,
to [email protected],
date Feb 7, 2008 9:53 PM
subject [wxqc] changed recommendation for APRS servers
mailing list wxqc.lists.gladstonefamily.net
Pete Loveall, the author of the software used by all the APRS-IS servers
has contacted me and requested that all CWOP members always use a server
designation of “cwop.aprs.net” and port 14580. This is a change from
earlier CWOP recommendations made here. Specifically, don’t use
“rotate.aprs.net” and don’t use the name of an individual APRS-IS
server. This will make it much easier when CWOP is migrated to another
set of servers.
