How odd…my setup has run without a single hiccup (touch wood) throughout the time it has been installed (about 18 months all told through various updates)…I’m running Win XP SP 2 and all updated…serial data logger…VVP 1.1.4.22…WD, VWS, WL, running continuously and occasionally VPLive on Com ports 6 thru 9…
I too had run it around 18 months with hassle, exactly the same as you, running xp sp2, all up to date etc…
One day, it just decided not to want to connect anymore, always stopping at different records when downloading.
I haev always used weather display and weatherlink, i started to use wetterstation in august, by october/november VVP gave up, never connected to successfully since. - nothing had changed (that i am aware of), really strange
i have had VVP running myself, latest version, to test out the TCP/IP connection
no problems here either
so I dont myself see any need for a new version that is more “robust” as you put it
maybe try reseting your data logger (completly power it down and remove it for 5 minutes)
or maybe the VVP archive records are corrupted (and need to be reset) or similar
I’d have to agree with the above posts. I found files with dates from around March 2006 when I must have started using VVP. I have not had one problem with it. I have VP2 with VVP feeding WD, WL, VPLive on virtual com ports with WL and VPLive connection via TCP/IP over a LAN.
So I would suspect a set-up/hardware problem vs a less than robust program.
I have tried resetting it “if that is the same as clearing it” via both weather link and weather display, no luck there, but i will try disconnecting the logger from both the console and the computer for 5 minutes though, that’s a good idea. Will 5 minutes be enough?
(and please, don’t you all jump on me saying the software is great and the problem is most likely my fault, as i agree, the software is fantastic and up to when it had issues with the datalogger, i had no issues, but i have done nothing to stop it from working!) this is great software!! and i only ask about the more robust software as that’s what is stated in the roadmap for future versions on the softwx site!!!
I have suspected it to also be a hardware problem (not a setup, nothing has changed!) but maybe wetterstation causing an issue
OK, have tried that, no luck either.
Tried using my other VP2 console too, again, the same result.
Personally i am thinking it is the datalogger, but it connects fine to weatherlink, weather display and wetterstation without any trouble (though weatherlink does occasionally stop and have to retry on obtaining a record or 2!).
While VVP “just works” for the vast majority of people, there are a few people that have problems with it on their system. Most of these problems I can’t duplicate, but I think I know what the problem may be. Some I can duplicate, so I do know what the problem is. Some I can’t duplicate, and just don’t know what the problem is. I am working on these issues, although I don’t have a firm date when I will have a release. I definitely haven’t abandoned my interest in VVP. In fact, I have some interesting plans for it this year that I think folks will like.
Available time has been an issue in the past. Not happy with this, last month I rearranged the schedule of contract programming that is my main income, and let go some of the work I was doing. This should make my time schedule more sane.
Brian,
I have seen some “serial data” applications that are more fault tolerant to glitches in the serial data than others.
Also where plug & play can think some devices attached by serial cable are a mouse which again can make the serial app behave poorly or not work at all.
And of course if the person’s PC has lots of serial ports these may clash with VVP’s virtual ports causing issues.
I did however forget to ask what errors VVP actually gives Steve (stuartturrell) when he runs the app?
If you are feeling bold they may be an option in your computers BIOS setup program to disable the inbuilt modem which may be using some interupt used by a com port.
Or as an alternate, in device manager a right click of the item, preoperties and disable (if option available).
Next I would navigate to C:\Program Files\VirtualVP folder and rename or delete of the two ArchiveCache files and then try VVP again (other weather apps closed of course to free VP com port).
That will make it read the whole logger memory in from fresh should the data in one of those two files be corrupt.
Also are you on the latest release of VVP which I think is 1.1.4?
i’m just about to re-install XP, so i am feeling bold, but before i start teh new installation, i will pop into the bios for a look around and disable that modem!
The archieve deletion thing, i tried that, made no difference there. (deleted both the archive files)
OK, re-installed XP sp2, only install vvp, wd, wl and wetterstationand so far all is well.
I am upgrading the harddrive next weekend, when i re-install everything again next week, i will install back to how it was the other and find out what was causes issues with VVP. I get a feeling maybe my bluetooth adapter
