I was reading many different threads about cable extensions, replacement with sheilded/cat5 cable etc… now I can’t find the one I was going to reply to! #-o
Anyway here is some technical info that may be useful to people modifying their anemometer cabling for starters…
The four wires have the following function… ( looking at the anemometer plug, cable towards you, pins up, left to right )
Pin 1 (left) : Common (ground) - This connects to the battery -VE in the temp/hum., this is what any new cable shield should connect to.
Pin2: Anemometer power enable - This is the control line that when pulled to GND by the temp/hum module fully powers up the anemometer and causes its latest reading data to be sent back.
Pin3: Permanent power to the anemometer - continuously fed from battery or base V+
Pin 4 (right) : Serial data line from the anemometer to the temp/hum
In my unit the wire colours 1 - 4 are yellow, green, red, black, but this could be different in other units.
I had 30 metres of sheilded security alarm type cable running for a few years with no problems so extensions to at least this length should be fine!
If using cat5 cable use one colour for each of the enable/power/serial data pins 2,3,4 and connect all the others together to Pin 1, this should give best interference rejection…
Hope that may be of help to anyone doing mods I have the old station here and am quite happy to do any reverse engineering that may satisfy someones curiosity and mine!
