Min/max inside temp on **wxdial.gif
Trivial little issue. Is there something weird/different with the min max indicators on the inside temp bar indicator on wxdials.gif? I notice that if I restart the program they are way off (50F), although all the other min/max indicators on that gif seem to get it right. This is 9.91a.
i will investigate
probbaly a problem with oF etc
I found a long standing bug where you have ticked under units the internet settings are different…and the hi/lo markers for the dials were being set wronf for oF etc…
but not sure if this fixes this reported bug
I installed 9.94 and tested, the problem didn’t go away. The indoor temp min/max arrows are around 50F, but the temp hasn’t been in that range. I froze the webpage at;
www.kirkwoodmanor.com/wxsnap/montwx.htm
