I’ve got a tentative new version of WXSIMATE you can try. It addresses the web client problem with MOS data in two ways.
First, if you do access that site in auto mode, WXSIMATE should now skip the error messages so that the run can complete. On average it seems it should get about two out of the three MOS products. I still have no idea what caused this problem to appear, other than that it must be something on the server end.
Second, there’s a new option: FTP (thanks for the suggestion, Kevin!). It turned out I had to do this in a rather roundabout way, as VB.Net does not make it easy to use FTP prorocol (it seems I would have to download some kind of plug-in, that would probably only work in Net Framework 2.0, and then learn how to use it). What I did was to have WXSIMATE create DOS batch and script files and run them to get the MOS files via FTP, through Internet Explorer (I think). This works quite well on my computer, and may actually be faster than the first option. A slightly odd aspect is that you see the command window’s icon appear up to three times for a couple of seconds each down on the bottom task bar. Also, an hourglass may appear for a few seconds, preventing updates of WXSIMATE’s status bar, so that it skips right from “Searching for GFS MOS…” to “Files appended”, without telling you about the culling process or advancing the blue progress bar. That’s OK, though, because it does do everything, and pretty quickly!
I’ve posted the program on my web space, but not accessible from the web page itself. Instead, just go to www.wxsim.com/wxsimate.exe and choose “Save”, and save it to c:\wxsim (or whatever your WXSIM folder is called).
You should notice two things different when you run WXSIMATE: there’s a new box for the UTC minute value (to the right of month, day, hour). This helps WXSIMATE know what MOS files should be available for download. Also, on the MOS list box, there should now appear arrows for drop-down on the right. The http source will still be in the box (at first), but you can now scroll down to the ftp choice right below it, and click on that to select this new option.
You might want to try the old option first, in auto mode, just to make sure it really doesn’t stall the rest of the process. Again, this should largely work, omitting an average of one of the three sources. I still want it as an option.
I’m interested in the behavior of the new option, of course. First, confirm that it works. Second, take note of whether the hourglass appears, and whether the progress bar and status bar update (no big deal if they don’t, but I’d like to know).
By the way, I believe that, at least with the new option (and possibly with the older one as well), all checked MOS products will be included in the final data file, even if they weren’t downloaded on this try (it will patch in old data from the latest successful run). I think this is a good thing (better old data than none - up to a point), but will think about it some more.
I also am updating WXSIM itself. The main item on the agenda this time is the Auto Haze option. I’ve rarely used it, but have refined it considerably and will be recommending its use in general in the future.
Let me know how it goes!
Tom
