I have WD using data from a Davis VP2; I have just installed mcsSprinklers software to control my sprinkler system. I would like to send data from WD to mcs so that my sprinklers only operate if evapotranspiration requires it. mcs is looking for data in a csv format each day to determine this.
Does anyone have any familiarilty with mcs and what it needs from WD?
I think I know what mcs needs. How do I set up a custom template? I tried to set up a custom tag file, but was unsuccessful. It doesn’t output and I can’t seem to make a special file and control when and how often it outputs data.
Alter the customtext.txt file in the webfiles subdirectory or create customtext2.txt
You can use “Custom Tag Files” editor on the “Control Panel” or MS-notepad to enter
the tags %temp%,%hum%,%VPet%,%avgspd%,%dayrnusa%,%VPuv%,%VPsolar%
THEN…
Under “Setup” on the main menu bar
Click on “Log Files”
tick “Produce a custom log file”
set the frequency
Make sure the Main Switch is “ON” then click on “OK” to exit
customtextout.txt should update in the webfiles subdirectory.
Hope this produces the file you need to control your sprinkler system.
I have OpenSprinkler* and they’re screwed by the WU API situation because that was their only wx source. They have quickly come up with a firmware update to use PWS Weather but based on forum comments it doesn’t seem to be working well yet
