Im trying to set up jpgraphs as described in the first post. However when I download the jpgraph file from the jpgraph site I get a file called “jpgraph-3.5.0b1.tar” this is a GZ file. Is this right ? I can’t find the “jpg-config.inc.php in the jpgraph-x.xx/src folder”… What have i done wrong? Any help on this one would be great
I just downloaded the jpgraph-3.5.0b1.tar.gz file and I see jpg-config.inc.php in the /src folder. How are you extracting the files from the tar.gz archive? If you don’t have a windows extract program for tar/gz I can recommend 7zip.
Thanks Niko
You’re right. I was not unzipping the jpgraph-3.5.0b1.tar.gz file, just opening it in note pad! Just opening it in note pad, no wonder I couldn’t find anything.!!
Thanks again. I will give 7zip a try later.
And I think it’s just a limitation of the graphing program that it doesn’t plot a 100 line along the top of the graph. If you changed the humidity scale to 101 max I think it would plot the 100 line. I think the legend would still stop at 100 so it would still look OK.
I am using version 2.1.0 of the steelseries gauges . When I look at the wxgraphs graphsconfg.php I see the color for solar should be gold. Mine is blue. Humidity should be darkgray mine is blue. Same for humidity. I tried changing the colors in the conf file but the colors of the popup did not change. Any ideas?
Hi Guys, definitely Great software and Huge potential, I have already accomplished to get the data from our weather station online with Weather Display Live and created the Graphs with Wxgraphs, however just 2 doubts to make it Brilliant…
1- How to change the barometer scale on wxgraphs php because it is set from 940 to 1060, sometimes a 10 mb drop is barelly noticed…
2- How can I have the wind direction graphs show the wind direction average of only day time (say for example from 8 am to 10 pm) this way I could really see how is the wind behaving at the location during all day, since the night time messes up the graph with pretty much all wind directions and does not interest us.
Having some trouble getting graphs to work on mouseover. I am pretty sure I have followed the instructions carefully. If I try to open a graph in a web browser (wxgraphs/baro_1hr.php) for example, I get this error.
Parse error: syntax error, unexpected ‘$’ in /home/content/03/10235403/html/wxgraphs/graphsconf.php on line 20
I have wxgraphs and jpgraph-3.5 in separate folders under my root.
This is from graphsconf.php:
$hostloc //$hostloc = “${WEBROOT}/”; //must have trailing slash
= “${WEBROOT/”;
$jploc = “${WEBROOT}/jpgraph-3.5/src/”; //must have trailing slash
