How to setup jpgraphs and wxgraphs
Tim,
Sorry the ./ was removed. Typo on my part.
These are the errors:
Warning: main(/home/content/k/4/r/k4rcb/html/jpgraph-1.22.5/src/jpgraph.php): failed to open stream: No such file or directory in /home/content/k/4/r/k4rcb/html/weather/wxgraph/baro_24hr.php on line 4
Warning: main(): Failed opening ‘/home/content/k/4/r/k4rcb/html/jpgraph-1.22.5/src/jpgraph.php’ for inclusion (include_path=‘.:/usr/local/lib/php’) in /home/content/k/4/r/k4rcb/html/weather/wxgraph/baro_24hr.php on line 4
Warning: main(/home/content/k/4/r/k4rcb/html/jpgraph-1.22.5/src/jpgraph_line.php): failed to open stream: No such file or directory in /home/content/k/4/r/k4rcb/html/weather/wxgraph/baro_24hr.php on line 5
Warning: main(): Failed opening ‘/home/content/k/4/r/k4rcb/html/jpgraph-1.22.5/src/jpgraph_line.php’ for inclusion (include_path=‘.:/usr/local/lib/php’) in /home/content/k/4/r/k4rcb/html/weather/wxgraph/baro_24hr.php on line 5
Fatal error: Cannot instantiate non-existent class: graph in /home/content/k/4/r/k4rcb/html/weather/wxgraph/baro_24hr.php on line 32
The page is http://www.dominion-llc.com/weather/wxgraph/baro_24hr.php
As you can see I am very much a novice at PHP.
Rick
I’m also having a problem. My clientraw files, jpgraph, and wxgraphs are all located at /wx/
My config files is set as follows:
//where are your clientraw*-files and JPGraph relative to where this file is
//note you should only need to change the jpgraph directory if you do not use standard names
$hostloc = “${WEBROOT}/”; //must have trailing slash
$jploc = “${WEBROOT}/wx/jpgraph-1.22/src/”; //must have trailing slash
If I try to load a image from the wxgraphs directory I get a page not found error. I can see the file is there when I ftp to the same directory. Any idea what I did wrong?
http://www.lesdiefenbach.org/wx/wxgraphs/rain_1hr.php
Kewee,
What folders did you create for jpgraph and wxgraph? Make sure the paths match exactly, including case.
dafuser,
Are all your weather files in /wx? I think you need to change $hosloc to reflect that.
Wxgraph and jpgraphs folders are setup under /weather and are named wxgraph and jpgraphs-1.22. All others files are in the /weather folder.
too.
Thanks for your help.
Rick
Yes, all files are under /wx/ I changed the WEBROOT to poit to /wx/ but still get the files not found error when I try to access any of the image files in the wxgraph folder
Could you both post the results of running hardpath.php?
My hardpath.php is located at:
http://www.lesdiefenbach.org/wx/jpgraph-1.22/ttf/hardpath.php
The results I get when running it are:
/home/content/d/a/f/dafuser/html/wx/jpgraph-1.22/ttf/
dafuser,
Use the rain_1hr.php in an image tag, like in the directions above.
And if you are getting a file not found error (I am too) then make sure the file is there. If it is there it may not work but you should not get a file not found error.
Here is my results:
/home/content/k/4/r/k4rcb/html/weather/jpgraphs-1.22/ttf/
Rick
I deleted the wxgraphs and jpgraph-1.22 directories. I downloaded fresh copies and uploaded them to my web site. I put test.php and hardpath.php in wxgraphs and jpgraphs/ttf/
http://www.lesdiefenbach.org/wx/wxgraphs/test.php - This works fine
http://www.lesdiefenbach.org/wx/wxgraphs/hardpath.php - This works fine
http://www.lesdiefenbach.org/wx/jpgraph-1.22/ttf/test.php - This works fine
http://www.lesdiefenbach.org/wx/jpgraph-1.22/ttf/hardpath.php - This works fine
Both jpgraph-1.22 and wxgraphs can be accessed by my browsers
All my weather files are located in /wx
My graphsconf.php in the wxgraphs folder looks like this:
$hostloc = “${/wx}/”; //must have trailing slash
$jploc = “${WEBROOT}/jpgraph-1.22/src/”; //must have trailing slash
My jpg-config.inc.php in the jpgraph-x.xx/src folder looks like this
// TTF_DIR:
// Directory where TTF fonts can be found. Must end with ‘/’
// The default values used if these defines are left commented out are:
// UNIX:
// CACHE_DIR /tmp/jpgraph_cache/
TTF_DIR /home/content/d/a/f/dafuser/html/wx/jpgraph-1.22/ttf/
// MBTTF_DIR /usr/share/fonts/ja/TrueType/
// WINDOWS:
// CACHE_DIR $SERVER_TEMP/jpgraph_cache/
// TTF_DIR $SERVER_SYSTEMROOT/fonts/
// MBTTF_DIR $SERVER_SYSTEMROOT/fonts/
// DEFINE(“CACHE_DIR”,“/tmp/jpgraph_cache/”);
DEFINE(“TTF_DIR”,“/home/content/d/a/f/dafuser/html/wx/jpgraph-1.22/ttf/”);
// DEFINE(“MBTTF_DIR”,“/usr/share/fonts/ja/TrueType/”);
I have the aerial font files loaded in /wx/jpgraph-1.22/ttf
I’m calling the images using www.lesdiefenbach.org/wx/imagetest.php using:
I don’t see anything but broken images. When I try to view the individual images at:
http://www.lesdiefenbach.org/wx/wxgraphs/month_baro.php
I get this error:
Parse error: parse error, unexpected ‘/’ in /home/content/d/a/f/dafuser/html/wx/wxgraphs/graphsconf.php on line 7
Trying http://www.lesdiefenbach.org/wx/wxgraphs/month_rain.php gets the same error:
Looks like it can’t find the clientraw files for some reason. Line 7 in my files shows it’s looking for the clientraw files:
//$clientraw = get_raw(“${hostloc}clientraw.txt”);
//$clientrawextra = get_raw(“${hostloc}clientrawextra.txt”);
$clientrawdaily = get_raw (“${hostloc}clientrawdaily.txt”);
The client raw files are in my /wx directory
http://www.lesdiefenbach.org/wx/clientraw.txt
12345 5.8 4.7 16 26.4 31 983.0 0.0 0.0 0.0 0.000 0.000 24.8 25 0.0 4 0.0 0 0 0.0 0.0 0.0 0.0 -100.0 -100.0 -100.0 0 0 0 14 42 47 Weather_from_the_shores_of_Lake_Granbury-2:42:47_PM 0 0 5 1 100 100 100 100 100 100 100 26.4 26.8 26.7 10.9 5 Dry -1.0 7 7 7 8 8 8 8 8 8 8 8 8 8 8 5 5 5 5 5 5 12.2 7.9 8314.5 1/5/2008 27.2 11.9 26.7 10.9 0.0 7 6 6 7 7 6 5 4 6 5 25.7 25.9 26.2 26.2 26.2 26.2 26.5 26.6 26.6 26.5 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 26.3 10.9 26.1 9.5 0 — — 38 0 0 -100.0 -100.0 -100 0 0 0 0 0.0 25.0 22.3 24.9 990.0 983.0 11 14:07 12:47 25.9 11.0 13.6 7.3 7 2008 0.0 1 -1 1 47 32 65 48 23 36 14 44 45 33 0.0 0.0 5.4 !!C10.37g!!
Does this help troubleshooting? It’s probably something minor I have messed up.
Here are the two variables I use:
dafuser,
I think yours should read:
$hostloc = “${WEBROOT}/wx/”; //must have trailing slash
Maybe a hint for people who have a webhost in safemode (just like me)
Only use abolute paths, like the hardpath one.
So in graphsconf.php the lines to your jpgraph and clientraw dir, remove the webhost part ( ${WEBROOT}/ ) and just write out the full path.
That does the job!
I gave that a try but still get the same error where it looks like it can’t find the clientraw files. They are in the /wx directory.
<?php // Obtain Basic Environment $WEBROOT = $_SERVER['DOCUMENT_ROOT']; //========================================== //where are your clientraw*-files and JPGraph relative to where this file is //note you should only need to change the jpgraph directory if you do not use standard names $hostloc = /home/content/d/a/f/dafuser/html/wx/; //must have trailing slash $jploc = "/home/content/d/a/f/dafuser/html/wx/jpgraph-1.22/src/"; //must have trailing slash
I fixed the problem and have the graphs working here http://www.lesdiefenbach.org/wx/graphs.php
It’ saying
“You have specified a min value with SetAutoMin() which is larger than the maximum value ussed for the scale. This is not possible.”
I think the error is coming from the month_baro.php.
Could you tell us what you found and how you fixed yours so we can fix ours?
Rick
In the jpg-config.inc.php I did not the WEBROOT variable as suggested above in this thread.
// TTF_DIR /home/content/d/a/f/dafuser/html/wx/jpgraph-1.22/ttf/
// WINDOWS:
I also had a space or two in the line DEFINE(“TTF_DIR”,“/home/content/d/a/f/dafuser/html/wx/jpgraph-1.22/ttf/”);
After I removed the spaces and started using the path information supplied by the hardpath.php in place of the WEBROOT variable it started working.
I will give that a try. Thanks for sharing.
Rick
I have a question, and a bit of advice:
Advice first: I (evidently) have a windows server, and if I call my fonts folder ttf as instructed here, something in the code interprets the “\t” as a tab which results in the path to the font folder becoming corrupt. I renamed ttf to fonts and lots of stuff immediately started to work…
Now the question: Not everything works:
http://www.kingsteignton-weather.co.uk/WXGraphs/wxgraphs_test.html
http://www.kingsteignton-weather.co.uk/jpgraph-1.22/src/Examples/testsuit.php
The error message is truncated so I can’t see exactly what’s going on:
http://www.kingsteignton-weather.co.uk/jpgraph-1.22/src/Examples/bargradex1.php
but there still appears to be something wrong with the fonts.
Does anyone know what I have done wrong?
These are the relevant lines from jpg-config.inc.php:
DEFINE(“TTF_DIR”,“e:\domains\k\kingsteignton-weather.co.uk\user\htdocs\jpgraph-1.22\fonts/”);
I’ll admit that the Windows path with the wrong slashes looks really dicey - I see everyone else here has Linux servers…
I’m not sure but I don’t think the fonts folders should reference a drive letter.
http://www.kingsteignton-weather.co.uk/jpgraph-1.22/fonts/hardpath.php
I’ve no idea how to supply the path on a windows server then…
