I’ve had a similar problem for the last week.
I recently had to move WD to another computer. I took the opportunity to update my version to the latest, and to try a few other WD features. That is when my problems started.
The 12 hour graph on the main display does not work properly. Andy had the best description of the problem. The time scrolls from right to left, but the weather values do not and consequently do not form a graph.
I have also notice a second issue: The Tempature Rate of Change appears to be computed from a fixed starting tempature of around 55F. In order words during the warmest part of the day I’m showing a +40F+ hourly rate of change, whereas just after dawn if maybe a more modest +25F hourly rate of change.
I can change the time span of the graph to either 24 or 48 hours and the graph presents the information normally, howerer the temp rate issue is unaffected.
I’ve tried many of the solutions presented on this thread and others to no avail. The logs appear to be updating normally. I’ve tried restarting WD, and rebooting the computer (several times).
Today, I did notice the following error messages:
ERROR: Access violation at address 006DB865 in module WeatherD.exe read of address 00000000 at time/date…
Note: This error comes up when I’ve restarted WD or rebooted the machine. Sometimes is comes up multiple times a few seconds apart, some times only once. Once it came up with an address of 006DC543, otherwise the message was the same.
The other error message:
ERROR: List Index out of bounds (-1) at time/date 2:08:49 PM 9/1/2003
Note: I’ve only seen this error once.
My equipment: Peet U-2000, WD9.90A, a Dell w/P4 at 2.5GHz, 256MB
I’ve found this fourm very useful in helping use WD, and hope someone can help me solve this problem. I’m not sure if I’ve set something incorrectly or if this is a rare program bug.
I really miss have the tempature rate change. It was great fun watching it drop like a rock during our recent monsoon season in southern Arizona.
Fred
