Hello,
I have a problem
Twice this week my VirtualVP has hung up twice and is not restarting it. Using version 1.1.1.2
Hello,
I have a problem
If you have a USB data logger, that is probably the problem.
Download and use version 1.1.4 of VirtualVP. It has code that can automatically reset the USB driver when it goes bad, thus allowing VirtualVP to get the connection to the console back up.
Steve
SoftWx
Hello and thanks for your reply.
I already installed the 1.1.4 version. But I have weather display and wswin32 which are working at same time. WD is working ok but I have problems with wswin32 which is always loosing the port. It seems to be not adapted to work with an USB port.
I think that I will have to change this usb port for a serial one.
Isabelle
