First of all, I would like to thank Brian for this amazing program and all the work you put into it. I don’t know how you do it - Kids, wife, weather, cows and everything else that life throws at us!
OK on to the problem. On the main screen of WD the weather metar (cloud graphic, etc) is now gone! All I have is a greenish box where the pic used to be (above the date and time). When I start wd and before it starts receiving data from my LaCross 2310 the graphic is there. After about 25 sec. it shows that WD is receiving data and the graphic disapears. Any help?
On the main screen of WD the weather metar (cloud graphic, etc) is now gone! All I have is a greenish box where the pic used to be (above the date and time). When I start wd and before it starts receiving data from my LaCross 2310 the graphic is there. After about 25 sec. it shows that WD is receiving data and the graphic disapears. Any help?Setup, Summary image/ Icon setup While playing with ticking different boxes on the
there must be some setting amiss
email me your wdisplay.ini file from c:\windows or c:\winnt
and export and email me your wdisplayftp.ini file from the registry
see here for how:
http://www.weather-display.com/exportregistry.html
Brian,
Mines been doing that too, for a couple of versions now. I had not changed anything, just upgraded. I did not mention it because I’ve been working with the linux version, and I know you’ve been really busy.
well, i did actuakly fix it that if you have do no thave ticked show icons on the main screen or dont show the partly cloudy icon, then those setting actualy work now
Err… I ment it was the windows version that was was doing it also. I’ve switched to the linux version, but keep the windows version running so it will update APRS and Anything Weather.
jeep, i will add in a hour offset so we can get UTC into the linux verison to get the aprs and anythign weather working
i will hopefully do that today
Brain, OOPS on my part. :oops: When I upgraded to 9.87 the icon had disapeared I must have unchecked something on the Icon setup page. My problem is fixed and I hope that all is well. Thanks again for a great program!
thats alright
its a case of something now actualy working like its meant to
