I’m running 10.37e on Windows XP-pro and have been having some quite regular crashes. I’m not sure what has changed, but this seemed to have started after I configured the new webcamcapture features.
When it crashes, I get this pop-up error message:
Exception: EInvalidOperation in module WeatherD.exe at 0004839E invalid ImageList
I see that there is now an 10.37f, I’ll try that to see if it helps. Should I shut off webcamcapture?
David
David,
Not having the problem but have you tried resetting your file save location (directory) just in case…
looks to me like a lack of available memory problem
The machine has 2GB of DRAM installed. The only other things running are the virus protection and the VM95 software. Memory usage is very low.
As I said this wasn’t a problem before I configured the new version of webcamcapture.exe. Now that I’ve upgraded to 10.37f I’ll wait a few more days and see if it continues.
Update: 18 Days 19 Hours 56 Minutes 35 Seconds, since upgrading with no problem…
That’s probably the longest I’ve run WD without interruption, so I conclude the problem was fixed.
