If you don’t get a better suggestion, I’ll look at my setting this evening and let you know what I have. I know mine works because when I shut down WD and am not fast enough StartWatch will have already started WD back up and it can’t do the update. I’ve gone to stopping the monitoring when updating.
Steve, will most likely be along soon to help out.
I’ve looked at all the files you sent and couldn’t find any clues in there as to why this is happening. I’m going to have to do some tests to try and duplicate the problem.
Any ideas as to why start watch isn’t starting any software??
I have since re installed it, entered my registration code again and set up virtual vp,WD and weather link.
Start up sequence works fine, I then close weather link, get the response stopping and that’s it?
While posting I have just shut down wd, that’s stuck on not responding… see attached.
Had to reboot the PC today, I closed all weather applications before doing so and start watch just sat there and did nothing at all.
And its got worse… on start up vpp encountered an error, start watch said no CPU activity and just left it at that, so all applications running with NO data!
So I have disabled start watch and will rely on the data saved in the data logger if there are any problems and check myself at regular intervials that all is well.
It’s weird. I can’t figure out what is different about your system that is causing it to not work for you. I’ll send you an email when I get the next version ready, and maybe you can try that and let me know if it works better for you.
It contains some bug fixes that may be the same problems you were experiencing. I’d like to know if these bug fixes solve your problem, or if there is still something lurking that I need to ferret out.
