Author Topic: Clientraw Description Documentation now in FAQ section  (Read 9412 times)
Offline TNETWeather
  • Kevin Reed (KrelvinAZ)
  • Gremlins are at work...
  • Mesa, AZ
« on: July 15, 2007, 05:03:41 AM »
I've added an article about Clientraw Description information in the FAQ section
http://www.weather-watch.com/smf/index.php/topic,25534.0.html
It provides links to documentation that describes all of the individual fields, their position, data types and notes that covers all four of the clientraw text files.
Offline looney2ns
  • Fearless Weather Dog-Loves to watch Lightning.
  • Near Evansville Indiana USA
    • Newburgh Weather
Re: Clientraw Description Documentation now in FAQ section
« Reply #1 on: July 15, 2007, 07:12:06 AM »
Thanks for taking the time to do that Kevin.  :)
Offline lulu836
  • Linda
  • Louisiana
    • Luv Retirement
« Reply #2 on: July 15, 2007, 10:56:31 AM »
Cool...........thank you.
Offline steve26
  • Drôme - France
« Reply #3 on: April 24, 2008, 07:47:54 AM »
Hello !
Are there new values in clientrawextra.txt file ? (with 10.37j build 10)
When I use Tnetweather clientraw parser, i get this result :
And when I use my own parser, i get this :
If someone could try  to parse it's clientraw*.txt file with tnetparser, to compare the results !
Thank you !
Offline broadstairs
  • Stuart
  • Broadstairs, Kent, UK
    • Broadstairs
« Reply #4 on: April 24, 2008, 07:52:11 AM »
Yes I think so, check out the clientrawdescription.txt file which was updated on 13th April (in main download not zip)
Offline steve26
  • Drôme - France
« Reply #5 on: April 24, 2008, 08:08:58 AM »
Thank you for the quick answer !
I forgot to look at this file :oops:
Ouch, not so easy to find only the new value in this file. Go :-)
Offline steve26
  • Drôme - France
« Reply #6 on: April 24, 2008, 08:21:43 AM »
Ok, the new values are :
Quote
****Record high dew month
hour of that record
minute of that record
day of that record
month of that record
year of that record
****Record low dew month
hour of that record
day of that record
year of that record
****Record high dew year
hour of that record
day of that record
year of that record
****Record low dew year
hour of that record
day of that record
year of that record
****Record high dew all time
hour of that record
day of that record
year of that record
****Record low dew all time
hour of that record
day of that record
year of that record
But I don't understand something.
In my first post (2nd picture), i see that there are 18 new values.
What corresponds to this in my clientrawextra.txt
Quote
7.7 10 39 11 04 2008 14.4 21 07 02 01 2008 14.4 21 07 02 01 2008
But according to my precedent quote, it seems that there are more new values than 18 !
« Last Edit: April 24, 2008, 08:30:30 AM by steve26 »
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #7 on: April 24, 2008, 08:46:02 AM »
there are 18
count again
(start with the wrongly labeled end of file)
Offline steve26
  • Drôme - France
« Reply #8 on: April 24, 2008, 08:50:50 AM »
Hi Brian.
In fact i'm not clear, sorry. (my bad english)
I'v have 18 new values in my clientrawextra.txt
But in the new clientraw's description file, i count 31 new value :
Quote
01-hour of that record
02-minute of that record
03-day of that record
04-month of that record
year of that record
06-hour of that record
07-minute of that record
08-day of that record
09-month of that record
10-year of that record
11-hour of that record
12-minute of that record
14-day of that record
15-month of that record
16-year of that record
17-hour of that record
18-minute of that record
19-day of that record
20-month of that record
21-year of that record
22-hour of that record
23-minute of that record
24-day of that record
25-month of that record
26-year of that record
27-hour of that record
28-minute of that record
29-day of that record
30-month of that record
31-year of that record
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #9 on: April 24, 2008, 09:47:42 AM »
my fault
I only added in the record high dew point data (month, year, all time)
and I forgot to add in record low  dewpoint
I will fix that
(this data is not yet being used by WDL, but will be for the next release of that)
Offline steve26
  • Drôme - France
« Reply #10 on: April 24, 2008, 09:56:29 AM »
No problem :-)
As i try to create my own graphs, I try to parse the clientraw*.txt files correctly.
Thank you !
Offline TNETWeather
  • Mesa, AZ
« Reply #11 on: April 25, 2008, 03:21:39 AM »
WD Parser is updated.  I will get to the documentation as soon as I get more time.
Offline steve26
  • Drôme - France
« Reply #12 on: April 25, 2008, 07:59:51 AM »
Thank you ! It works perfectly !
Offline Colin
  • Tegryn, Pembrokeshire, Wales
    • Coach House Cottage Weather
« Reply #13 on: September 20, 2010, 02:48:40 PM »
Thanks for the docs but I am looking for info on which is the most recent data in some of the fields ie the temp 1 - 20 is 1 the most recent or is 20.  Looking at my files it seems like 20 is most recent, can any one shed any light on this?  I am using consoleWD on Linux.
Colin
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #14 on: September 20, 2010, 07:31:12 PM »
oldest first
