Here is what i am seeing, was wondering over the last few days on what was going on. and now i see it.
Using the Ajax my heat index shows on my main page 96 and also other pages that are using ajax. But in Weather Display Live shows 88.3 which would be about right.
The code in ajaxWDwx.js for wind-chill, humidex, heat-index are all separate values … only the ‘feels like’ uses wind-chill or humidex based on temperature
Had a similar concern using the CarterLake templates with Ken’s ajax. The humidex values are much higher than heat index.
The %feelslike% tag definition is:
“Shows heat index or humidex or windchill (if less than 16oC)”
Does that mean I can configure somewhere in WD to have the tag use heat index instead of humidex? This is what I would prefer. Or do have have to change the tag to ajaxheatidx?
Guess I could also change Ken’s if/then logic in the script also?? :?
