When I view the error log in the Weather Display program it shows “Error:10057 Scocket is not Connected at Time” and the time is every 3 to 4 seconds. What have I done wrong?
you most likely have some real time ftp options ticked under setup, web files setup (which I now have in a separate setup page), like the java dials, jave web cam, client raw upload…
and you need a fast permanent connection…
untick those and then restart wd
Thanks for your replay. That seems to have fixed that problem, now I have something else to ask. The data on my web page that gives all the Current Weather and Current Temperature has not updated since 20:30 July 7. How can I fix this problem. Also on my web page there is a link to click for a daily update of the averages/extremes for the month. When you click the link the text is not there only the graphs. What can I do to fix this? I am new to this and have been working on these problems for 2 days to try an fix it by my self but I am at my witts end here. Any help would be appreciated. Thanks
first part:
post here the contents of your ftplogfull.txt file
2nd part:
that file should get updated/upload just after midngith (as long as you have that ticked under web upload times)
also check you dont have custom web page switch ON under setup, ftp/internet, custom web page setup
I open the ftplogfull.txt file and it is empty!
make sure you have ftp logging ticked under setup, ftp/internet setup, connections
Do you mean tick “Produce a Log File”? Also, the screen shot of the WD program does not show up on my web page just a box with an x in the middle is all tha is there.
yes
then after a upload, copy and past the contents of the that file here
Here it is.
list of files uploaded*
E:\wdisplay\webfiles\ Dobbins Weather Station.htm
E:\wdisplay\webfiles\ Dobbins Weather Stationdial.gif
E:\wdisplay\webfiles\ Dobbins Weather Station.gif
Permanent connection selected
Finshed email agenda
Finshed email agenda, and more Internet agenda items to do…
Logging onto FTP server…ftp.farmerstel.com
Connecting to FTP server.
Connected.
220 Welcome to (farmerstel.com). Enter username to continue.
USER ddobbins
331 Welcome ‘ddobbins’, enter password to login.
PASSWORD=****
230 User ‘ddobbins’ login successful.
TYPE I
200 TYPE is now BINARY.
CWD myweather
250 “/myweather” is the current directory.
Checking for next FTP agenda…
there are 1 more things to do
Doing ftp upload
Checking there are files to upload
There are more files to upload
PORT 192,168,1,100,10,5
200 PORT command successful.
STOR Dobbins Weather Station.htm
150 Starting BINARY transfer.
226 Transfer done. 9812 bytes transferred.
PORT 192,168,1,100,10,6
226 Transfer done. 133527 bytes transferred.
PORT 192,168,1,100,10,7
226 Transfer done. 13968 bytes transferred.
PORT 192,168,1,100,10,8
PORT 192,168,1,100,10,9
226 Transfer done. 8211 bytes transferred.
PORT 192,168,1,100,10,10
226 Transfer done. 8409 bytes transferred.
PORT 192,168,1,100,10,11
226 Transfer done. 8241 bytes transferred.
PORT 192,168,1,100,10,12
PORT 192,168,1,100,10,13
226 Transfer done. 8349 bytes transferred.
PORT 192,168,1,100,10,14
226 Transfer done. 8347 bytes transferred.
PORT 192,168,1,100,10,15
226 Transfer done. 8370 bytes transferred.
PORT 192,168,1,100,10,16
226 Transfer done. 8178 bytes transferred.
PORT 192,168,1,100,10,17
226 Transfer done. 227907 bytes transferred.
PORT 192,168,1,100,10,18
226 Transfer done. 16954 bytes transferred.
PORT 192,168,1,100,10,19
226 Transfer done. 13669 bytes transferred.
PORT 192,168,1,100,10,20
226 Transfer done. 4343 bytes transferred.
PORT 192,168,1,100,10,21
226 Transfer done. 10013 bytes transferred.
PORT 192,168,1,100,10,22
226 Transfer done. 7117 bytes transferred.
PORT 192,168,1,100,10,23
226 Transfer done. 13821 bytes transferred.
PORT 192,168,1,100,10,24
226 Transfer done. 14522 bytes transferred.
PORT 192,168,1,100,10,25
226 Transfer done. 15156 bytes transferred.
PORT 192,168,1,100,10,26
226 Transfer done. 14332 bytes transferred.
PORT 192,168,1,100,10,27
226 Transfer done. 47976 bytes transferred.
PORT 192,168,1,100,10,29
226 Transfer done. 115006 bytes transferred.
PORT 192,168,1,100,10,40
226 Transfer done. 6967 bytes transferred.
PORT 192,168,1,100,10,44
226 Transfer done. 14938 bytes transferred.
PORT 192,168,1,100,10,46
226 Transfer done. 30458 bytes transferred.
PORT 192,168,1,100,10,47
226 Transfer done. 14988 bytes transferred.
PORT 192,168,1,100,10,48
226 Transfer done. 2372 bytes transferred.
PORT 192,168,1,100,10,49
226 Transfer done. 2432 bytes transferred.
PORT 192,168,1,100,10,50
226 Transfer done. 2793 bytes transferred.
PORT 192,168,1,100,10,51
226 Transfer done. 2100 bytes transferred.
PORT 192,168,1,100,10,52
226 Transfer done. 2325 bytes transferred.
PORT 192,168,1,100,10,53
226 Transfer done. 2517 bytes transferred.
PORT 192,168,1,100,10,54
226 Transfer done. 2520 bytes transferred.
PORT 192,168,1,100,10,55
226 Transfer done. 7816 bytes transferred.
PORT 192,168,1,100,10,56
226 Transfer done. 9359 bytes transferred.
No more files to upload
All Agenda complete, doing FTP log off…
FTP logoff
QUIT
221 Goodbye, logging out.
Disconnected.
Doing abort procedure/program close
I am going to bed. I have an early time to get up in the morning. I also live on a fram and work a job in town. I have 2 400’ poultry houses that house 20,00 birds each. I’ check this post in the morning from work. Thanks you Brain for your help.
thats some important info there
you must have unticked use .html instead of .htm in the web files setup
so the new url is:
http://users.farmerstel.com/ddobbins/myweather/%20Dobbins%20%20Weather%20Station.htm
note , if you dont use spaces in the url, then you want get the %20 etc
sorry i didnt reply earlier, i was on the telephone
Brain I want to thank you for your help. I am sorry to hear that you are not feeling well. I have fixed most of my problems with your help. I have learned a lot in the last few days about something that I have never done before. I have one more thing that I need your help with if you are feeling well enough. The Daily Weather Report Average\Extremes has no text only the graphs. How can I fix this? Thanks
its sounds like you are missing the midnight time stamp in the log files
zip and email me the file 72003lg.txt from the folder logfiles…
i.e, if you dont have wd running overnight, then you need to have the data logger set to 1 minute interval for when it gathers the data in the morning
and or try, action, import log files, convert wd logfiles to grpahs, but tick graph file to log file, then click on the file month72003.inf, then click on convert
hey, you look alot like clint eastwood
and, i am feeling better , but throat hurts still bad
actualy, i fee like skin…hummm. i think that is normal, :roll:
Brain, I found out why the text is missing in the Weather Report Average\Extremes. I had the text color somehow set to white on a white background. I fixed and it is now OK. Only the days that were set to the white color are still not showing and I don’t know were to edit that in the file. Can you help? Thanks
is this in the program or on a web page?
(if the latter, then please point me to it)
(as i am a little lost as to where you are )
It is on my web page and in the files on my computer. Here is the link:
http://users.farmerstel.com/ddobbins/myweather/July2003.htm
You will have to go to edit and than select all befor the text will show up.
ahh
colour changes are not retrospective
but open up the july2003.htm file in notepad in your webfiles folder (just double click it)
and change the html colour code
Averages\Extremes for day :06 ***** CHANGE THIS
Ya! Thanks Brain, every thing is fixed now! :lol:
now if only i could fix a first time calvers pinched nerve (one legt is paralised) after calving (big calf) as easily!
Sorry to hear about the calf. I’ve had the same problem. Hefers always gave me the most problems with thier frist calf. If you don’t watch them close you could loose them both.
