Are you sure you downloaded both image packages?
There is one large package with icons like partlycloudy-d.png and then there is a update package for the pop images…
You may want to check with your host to see if they have GD installed. The script could very well be failing when it’s trying to overlay the PoP on the image.
In gd 1.0, it stood for “gif draw.” After the Unisys patent on the LZW compression used in GIF came to light and GIF support was dropped, it did not officially stand for anything, but let’s just say “graphics draw” and leave it at that. (GIF support is back, thanks to the expiration of the patent, but gd can draw much more than GIFs.)
There’s a script on http://saratoga-weather.org/scripts.php that you can upload and call that will show what PHP and GD (if any) you are running. That’ll probably be quicker than waiting for tech (non)support to answer your question.
Thanks for the GD explanation. I ran the test file and GD is supported, pasted below.
Does PHP work?
Yes, it does. PHP Version 5.0.4
To run the WXSTICKER script, you need GD enabled in PHP.
Current GD status:
GD support: yes
GD Version: bundled (2.0.28 compatible)
FreeType Support: yes
FreeType Linkage: with freetype
T1Lib Support: no
GIF Read Support: yes
GIF Create Support: yes
JPG Support: yes
PNG Support: yes
WBMP Support: yes
XPM Support: no
XBM Support: yes
JIS-mapped Japanese Font Support: no
If you don’t see “Yes, it does.” above, then PHP is not enabled.
I have tried everthing to get the icons to display for the last 3 weeks, is there anybody that can help me solve this? would be much appreciated so I can move on.
