Author Topic: USB and multiple comm ports  (Read 6032 times)
Offline weatherfront
  • The Weather Shop™
  • Eastbourne, UK, MSL+5
    • The Weather Shop ®
« on: July 03, 2003, 06:39:46 AM »
If you are short of comm ports these people make a range of great USB to multiple comm port devices.
http://www.easysync.co.uk/
We have one that has a Vantage Pro, WMR928, WS2300 and WS2500 all running in real time with the PC.
The Weather Shop ® - www.weathershop.co.uk
Online Weather Display
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #1 on: July 07, 2003, 09:18:20 AM »
sounds good!
Does WD run ok with this USB to com port adaptor ( i have one here but I have had some problems)
Also, does WD work with the WS2500?
Thanks!
  • The Weather Shop™
« Reply #2 on: July 07, 2003, 11:01:04 AM »
It is working fine Brian.
As it is our instore demo we run;
OS WMR928 to WeatherDisplay
Davis VP+ to Weatherlink (and occasionaly WeatherDisplay)
La Crosse WS2300 to Heavyweather (and occasionaly WeatherDisplay)
All concurrently.
I have tried a Kestrel interface at the same time with no probs.
Haven't played with the WS2500 yet I had a demo on loan from the distributor a few weeks back and stock is due any day now.
The machine is an small format NEC 1.8 Athalon, 256Mb and XP-Pro.
We are using the 4 port version. Set up was easy. I found that I had to ignore the comm port numbers printed on the casing and work out what was connected to what but it only took a couple of secs.
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #3 on: July 07, 2003, 07:16:04 PM »
cool...let me know if wd works with the ws2500 (choose that in the weather station type...it will get the data every 5 minutes)
