Real Time Graph: why does it open to data a week behind?
When I double-click on my graph to open the real time graph, it always shows me data from a week ago. Is there a way to get the real time graph to show the latest data so I don’t have to scroll a long ways up to the current day?
humm
thats odd, it should not do that
what do you have set for the maxximum records?
and or try cliking on the clear records to reset/restart it
When I double-click on my graph to open the real time graph, it always shows me data from a week ago. Is there a way to get the real time graph to show the latest data so I don't have to scroll a long ways up to the current day?
That use to happen to me sometimes. It hasn
Brian, max records set to 50,000,000 (honest!). And when I click on clear records, I wipe everything out which I don’t want to do. I want to be able to scroll back and see the detail.
BC, I’m running 9.79e, the latest version.
ok, thats the probem…with alot f records like that, its not forwarding on far enough
i will auto adjust the forward on to the maz records
as your recordes fill up, i would suspect wd would use gradualy more memory
note:
you can go to view, grpah history, then select a day, then click on real time graph, then you have the real time graph for that day…and then scroll back, or use the < > button in the top left to go back by 6, 12, 24 hours etc, or even select a month to date, start/end day
vers 9.80 should be better
:smiley: I’ll give it a try…Thanks!
9.80a is now the one
