Author Topic: indoor temp  (Read 1143 times)
Offline chrisv
  • Birmingham, AL
    • http://www.theviolas.net/weather
indoor temp
« on: June 12, 2003, 03:01:34 AM »
Not sure if this is a bug or setup issue but on the main screen I have Indoor Temp that appears at random. I do not have an indoor sensor defined in the dallas setup. I have temp/humidity sensor for outdoor and soil temp. Also one built into the anemometer but I do not have it defined. It is weird because it always shows the temp as 32degrees F and comes and goes. Nothing major....just wondering if anyone else has seen this. Been going on for a while but like I said...nothing major. Program is running great!
Brian...you probably don't hear it as much as you should but many thanks for your hard effort. Very few bugs lately. Just been sitting back and watching WD work. It is a great tool to have!
thanks
chris
1-Wire network - air and soil temp, humidity sensor, barometer, anemometer, lightning detector, and solar sensor.
  • Davis VP2
  • New Zealand
    • Weather Display
indoor temp
« Reply #1 on: June 16, 2003, 06:16:27 AM »
i had the same problem....
but a new 9.79e is better hopefully
32oF is 0oC  i.e a default reading
