Brian,
I have noticed a bit of oddness when trying to start weather-display with my new 2310. if you close the program, and then re-open it, it locks on trying to retrieve the history. You can close it and re-open it and it will work fine. Also, I noticed that if you set it to retrieve history for more than 5 minutes, it will just sit there. I wish it would poll faster than it does… (just a wish).
Zach
ok, i will do some testing and fix
also, do you mean, after starting it, you then go and set the history retreive, but it does not work?
i will add some sort of time out…
This is on start, when it tried to get the history automatically (it does this each time I startup the program.
i will add some sort of time out...
