is the time on the pc jumping around maybe by 1 minute at a time?
or maybe that when wd is busy doing things, the time used to update the file is 1 minute late at that point?
i think that is what might be happening…so if i get wd to grab the updated actual current minute then that should fix it
I have now been creating all-day video all day today and i think its running fine. I havent discovered any faults in the wmv file or the jpg webcam files.
Thank you very much.
If possible and without too much trouble - it could be very nice if you could make 30 seconds creation work the same way with 3rd party work…
i suspect its the 30 second files getting mixed up with the 1 minute files…
i will do some investigating and testing of using 30 second http download option
i think i see the problem
in the 3rd party web cam setup
you have set the destination file name, gif file name, as a .jpg file, when it should be a .gif file
as there is a separate entry for the jpg file (which you do have setup as well, good)
actualy, i have found and improved things (change that above too)
the creation of the output file via the 3rd party webcam setup will now sync correctly with the main WD minute timer…it was not before
and use this update: http://www.weather-display.com/downloadfiles/WeatherD.zip
build 07
test and confirmed its OK now (I was able to duplicate the problem before)
