Ok, I’m guessing I’m missing a setting somewhere.
I have the following set to start up by SW when windows starts.
Weather Display 1 minute after SW starts
Nexstorm 30 seconds after WD starts
OddCast 30 seconds after Nexstorm starts.
I have in options turned on Run Startwatch when Windows STarts and Auto begin startup sequence when SW runs.
All the delays work except Weather Display, it starts up immediately with SW.
Also, I have selected to Automatically shutdown Startwatch After all programs have started.
But SW instead gives me a dialogue box that asks “Close the applications started by SW before Closing” And start watch never closes.
Windows XP Pro.
and put it in your StartWatch folder. Let me know if that doesn’t fix the problem. This was reported earlier, and is fixed in that version. The fix will also be in the next official release.
Nope, didn’t change anything.
WD still starts up immediately, and start watch doesn’t close automatically, it pops up the close appliacations started question box.
Thanks!
I’m having a similar problem with the startup delay in StartWatch.
I just installed StartWatch on a second PC and currently have it set to start ImageSalsa and Oddcast two minutes after StartWatch launches. I’m running version 1.0.2. The programs start well before that time, like the time code is being ignored.
My settings:
Run when windows starts: checked
Automatically begin startup sequence: checked
Automatically close after sequence finishes: NOT checked
Ok, I’m an idiot #-o I didn’t copy the new file correctly somehow. I did it again, and that cured the delayed startup problem…but I still get the dialogue box instead of SW shutting down.
Thanks!
