I have an extra !-Wire temp sensor. I want it to show up on the main display. How do I do this?
Anyone know how to do this? I’ve forgotten how…
I have an extra !-Wire temp sensor. I want it to show up on the main display. How do I do this?:roll:
try giving it a name in the dallas setup…
but i will do some testing
i also need to have it that if you duisplay wind run, then it will toggle with a temp/hum sensor
I used to have the extra 1-wire temp sensor showing up right under Dew Point Depr. I currently have it named under Setup and it shows up as such under Setup but not on the main display.
Bob
ah, that is the indoor temperature
but in the dallas 1 wire setup, you can set which extra temperature sensor to use as the indoor temperature,…and you can give it a new name too, under setup, general and misc
Thanks, Brian, that’s what I forgot…and a number of other things as well! Oh, it’s terrible to get old.
