There seems to be a problem with my wind/temp/rain graph on my web site.
- the graph is cut off.
- the solar readings are not showing.
http://dgriffin.topcities.com/windtempraintrend.gif
The graph looks fine and contains the solar reading in WD.
Anyone else having this?
Do I have a setting wrong?
Dave[/url]
if you have XP and you are using the XP thick window bar style, that might cause that
or if have large fonts in use, it might cause that
BUT
a while ago I set the 3D graph as a separate image to get around this problem
so if you use the latest vers of WD it will be OK
i.e see mine:
and
Any way to get the Temp/windspeed this month/ this month last year to plot in
No the labels on the right side of the bottom graph are in C.
grab a new 9.79 …should be ok for the 3D graph
