Auto scale graph does not display 1 Wire temp
Thanks for the graph names for the extra graphs! The extra graph # 3 name does not save and now the outdoor temp/humidity from the WM918 is plotted on extra graph #3 and it is also plotted on the second graph down from the top. The extra graph #1 still only has the Dallas 1 wire humidity info plotted on it, this should have temp and humidity. Can you get the temp/humidity info from the extra temp/humidity sensor to plot together on one of the extra graphs? I now have an extra temp only 1 wire sensor and it plots on the extra graph # 2 just fine. Also, when I RC on the graphs and pick the Dallas 1 Wire Extra Graphs, the 2 sensors, one is the temp/humidity and the other temp only, plot correctly on graph 1 and graph 2.
Thanks again for all your help
Kevin
email me your wdisplay.ini file from c:\windows or c:\winnt
and your wdisplayftp.ini file from the registry using regedit.exe
thanks
