The Up or Down arrow is actually after the Hi/Low temperature reading in the html from NOAA…
I have a modified carterlake advforecast that handles that (assuming images are in the /forecast/images directory)
<?php
//This is a more advanced version of the forecast script
//It uses file caching and feed failure to better handle when NOAA is down
// modified by Ken True - Saratoga-weather.org -- 15-Jan-2007 or XHTML 1.0-Strict
//import NOAA Forecast info
//data ends up in three different arrays:
//$forecasticons[x] x = 0 thru 9 This is the icon and text around it
//$forecasttemp[x] x= 0 thru 9 This is forecast temperature with styling
//$forecasttitles[x] x = 0 thru 12 This is the title word for the time period
//$forecasttext[x] x = 0 thru 12 This is the detail text for the forecast
//$forecastupdate This is the time of last update
//$forecastcity This is the city name for the forecast
//$forecastoffice This is the NWS Office providing the forecast
//Also, in order for this to work correctly, you need the NOAA icons (or make your own...
//there are over 200!). These need to be placed in the path where the original NOAA icons
//are located. In my case, they are at: \forecast\images\
//properly (so make a folder in your web HTML root called "forecast", then make a folder in it
//called "images", and place the icons in this folder)
//http://members.cox.net/carterlakeweather/forecasticons.zip (380K)
//URL below --MUST BE-- the Printable Point Forecast from the NOAA website
//Not every area of the US has a printable point forecast
//This script will ONLY WORK with a printable point forecast!
//To find yours in your area:
//Go to www.noaa.gov
//Click on the Storm Watch map (middle lower left of page)
//Click on your state
//Click on your area of the state
//Scroll down to the "Additional Forecasts & Info"
//Click on Printable Forecast
// Get the forecast.txt file or a new one from NOAA
// You have to have a forecast.txt in place for this script to work
// You can see ours at http://www.carterlake.org/forecast.txt
// This is version 1.1 with Ken's modifications from Saratoga Weather
// http://saratoga-weather.org/
// You can now force the cache to update by adding ?force=1 to the end of the URL
if ( empty($_REQUEST['force']) )
$_REQUEST['force']="0";
$Force = $_REQUEST['force'];
$cacheName = "forecast.txt";
$fileName = "http://www.srh.noaa.gov/forecast/MapClick.php?CityName=Gulf+Shores&state=AL&site=MOB&TextType=2";
// The number 1800 below is the number of seconds the cache will be used instead of pulling a new file
// 1800 = 60s x 30m so it retreives every 30 minutes.
if ($Force==1) {
$html = fetchUrlWithoutHanging($fileName,$cacheName);
$fp = fopen($cacheName, "w");
$write = fputs($fp, $html);
fclose($fp); }
if (filemtime($cacheName) + 1800 > time()) {
$html = implode('', file($cacheName));
} else {
fclose($fp); }
// Just get the top of the NWS page for editing
preg_match('|<tr valign ="top" align="center">(.*)<table width="670"|s', $html, $betweenspan);
$forecastop = $betweenspan[1];
// Chop up each icon html and place in array
preg_match_all("/<td.*>(.*)<\/td>/Uis", $forecastop, $headers);
$forecasticons = $headers[1];
// saratoga-weather.org mod: fix up html for XHTML 1.0-Strict
$Status = "<!-- \n" . print_r($forecasticons,true) . "-->\n";
for ($i=0;$i<=8;$i++) {
$forecasticons[$i] = preg_replace('|/forecast/images|Uis',
'./forecast/images',$forecasticons[$i]);
\s+$|is',
"",$forecasticons[$i]);
// $forecasticons[$i] = preg_replace('|temperatures|is','temps',$forecasticons[$i]);
// $forecasticons[$i] = preg_replace('|Falling|is',' Falling',$forecasticons[$i]);
$forecasticons[$i] = preg_replace('|\'|is','"',$forecasticons[$i]); // change all ' to "
$forecasticons[$i] = preg_replace('|\\\\" >
|is','" />
$forecasticons[$i] = preg_replace('|<font color="(.*)\">(.*)</font>|Uis',
"<span style=\"color: $1;\">$2</span>",$forecasticons[$i]);
preg_match_all('|
([^<]+)(<span.*</span>.*)|is',$forecasticons[$i],$matches);
// $Status .= "<!-- matches\n ".print_r($matches,true). "-->\n";
if(preg_match('|<img .*>|i',$matches[2][0])) {
$t = $matches[2][0];
$t = preg_replace('|<img src="([^"]+)" (border="0") alt="([^"]+)">|i',
"<img src=\"./forecast/\\1\" style=\"border: none;\" alt=\"\\3\" title=\"\\3\" />",$t);
$matches[2][0] = $t;
$forecasttemp[$i] = $matches[1][0] . $matches[2][0]; // just the temp line
// remove the temp from the forecasticons
$forecasticons[$i] = preg_replace('|'.$matches[0][0].'|is','',$forecasticons[$i]);
// fix up the
to be
for XHTML compatibility
|Uis','
// $forecasttemp[$i] = preg_replace('|
|Uis','
',$forecasttemp[$i]);
// $forecasttemp[$i] = trim($forecasttemp[$i]);
$Status .= "<!-- \n" . print_r($forecasticons,true) . "-->\n";
// end saratoga-weather.org XHTML 1.0-Strict mod
// Now get just the bottom of the NWS page for editing
preg_match('|</table>(.*)<hr>|s', $html, $betweenspan);
$forecast = $betweenspan[1];
// Chop up each title text and place in array
preg_match_all('|<b>(.*): </b>|Ui', $forecast, $headers);
$forecasttitles = $headers[1];
// Chop up each forecast text and place in array
preg_match_all('|</b>(.*)
$forecasttext = $headers[1];
// Grab the Last Update date and time.
preg_match('|Last Update: (.*)|', $html, $betweenspan);
$forecastupdated = $betweenspan[1];
$forecastupdated = preg_replace('|<[^>]+>|Uis','',$forecastupdated); // remove html markup
// Grab the NWS Forecast for (city name)
preg_match('|<b>NWS Forecast for: (.*)</b>|',$html,$betweenspan);
$forecastcity = $betweenspan[1];
// Grab the Issued by office
preg_match('|Issued by: (.*)
$forecastoffice = $betweenspan[1];
if (isset($doPrintNWS) && ! $doPrintNWS ) {
return;
if (isset($_REQUEST['inc']) &&
strtolower($_REQUEST['inc']) == 'noprint' ) {
return;
// end saratoga-weather.org mod
function fetchUrlWithoutHanging($url,$cacheurl)
// Set maximum number of seconds (can have floating-point) to wait for feed before displaying page without feed
$numberOfSeconds=4;
// Suppress error reporting so Web site visitors are unaware if the feed fails
error_reporting(0);
// Extract resource path and domain from URL ready for fsockopen
$url = str_replace("http://","",$url);
$urlComponents = explode("/",$url);
$domain = $urlComponents[0];
$resourcePath = str_replace($domain,"",$url);
// Establish a connection
$socketConnection = fsockopen($domain, 80, $errno, $errstr, $numberOfSeconds);
if (!$socketConnection)
$html = implode('', file($cacheurl));
return($html);
// You may wish to remove the following debugging line on a live Web site
// print("<!-- Network error: $errstr ($errno) -->");
} // end if
else {
$xml = '';
fputs($socketConnection, "GET $resourcePath HTTP/1.0\r\nHost: $domain\r\n\r\n");
// Loop until end of file
while (!feof($socketConnection))
$xml .= fgets($socketConnection, 4096);
} // end while
fclose ($socketConnection);
} // end else
return($xml);
} // end function
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<title>NWS Forecast for <?php echo $forecastcity; ?></title>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
</head>
<body style="font-family:Verdana, Arial, Helvetica, sans-serif; font-size:12px; background-color:#FFFFFF">
<?php
print $Status;
// if the forecast text is blank, prompt the visitor to force an update
if (strlen($forecasttext[0])<2) {
echo '
Forecast blank? <a href="' . $PHP_SELF . '?force=1">Force Update</a>
<table width="670" style="border: none;">
<tr align="center" style="background-color: #FFFFFF;">
<td><b>National Weather Service Forecast for: </b><span style="color: green;">
<?php echo $forecastcity; ?></span>
Issued by: <?php echo $forecastoffice; ?>
</td>
</tr>
<tr>
<td align="center">Updated: <?php echo $forecastupdated; ?>
</td>
</tr>
<tr>
<td align="center">
<table width="100%" border="0" cellpadding="0" cellspacing="0">
<?php
print "<td style=\"width: 11%;\"><span style=\"font-size: 8pt;\">$forecasticons[$i]</span></td>\n";
</tr>
<?php
print "<td style=\"width: 11%;\">$forecasttemp[$i]</td>\n";
</tr>
</table>
</td>
</tr>
</table>
<p> </p>
<table style="border: 0" width="670">
<?php
for ($i=0;$i<=13;$i++) {
print "<tr valign =\"top\" align=\"left\">\n";
print "<td style=\"width: 20%;\"><b>$forecasttitles[$i]</b>
</td>\n";
print "<td style=\"width: 80%;\">$forecasttext[$i]</td>\n";
print "</tr>\n";
</table>
<p> </p>
<p>Forecast from <a href="<?php echo htmlspecialchars($fileName); ?>">NOAA-NWS</a> for <?php echo $forecastcity; ?>.</p>
</body>
</html>
I’d done this as part of the website design for Zeke’s Gulf Shores WX site and had seen the same issue as you did.
Ken
