Author Topic: Clientviewer Question  (Read 1966 times)
jadman
  • Guest
« on: May 19, 2003, 05:48:00 PM »
I noticed that there is an icon on the clientviewer that says "Updated" that flashes from red to green when I am connected. Will this icon change to solid red or something to give me an indication when the client is unable to communicate with the clientraw.txt file on the server?
Also, I noticed that even though the temp readout says 74 degrees F. the scale below it shows a blue line with a range between 40 and 60. It seems that it is not in sync with the temp reading above it.
-James
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #1 on: May 20, 2003, 05:44:33 PM »
it would seem the graph is still in oC
try restarting the program
the light flash when the time in the clientraw.txt file has changed ( i think)
jadman
  • Guest
« Reply #2 on: May 22, 2003, 04:40:34 AM »
Thanks for the info. Regarding the temp display I have noticed that when the temp gets above about 68 or 70 degrees F that the graph changes from F to C even though the numeric readout is still correct in F.
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #3 on: May 22, 2003, 06:05:30 AM »
please try vers 5.5
