I love the look of this add on, and would like to incorporate this into my web site. Unfortunately, I am a bit…um…slow… when it comes to setting up these things up and, despite reading the instructions, am still very much in the dark as how to do this. I have uploaded all the images to www.fortwilliamweather.com/wwwroot/wxsimforecast but I do not really understand what I need to edit in the wsofd.php file to make it all work. Also, can I automate the upload of the wxsim output plaintext.txt and how do I do it? Any help would be greatly appreciated as I am oh so confused!
hmmmm…tried that in word pad, saved it as info.php and uploaded it, and it says it does not exist. Tried opening on my desktop too, but 'puter said it could not open it. Beginning to think this may be a wee bit above my head!!! :oops:
On many forecasts produced by WxSIM, I see detailed verbage like:
Fair to partly cloudy in the evening, becoming mostly cloudy after midnight. A slight chance of a mix of snow and rain after midnight. Low 1. Wind west around 5 mps. Chance of precipitation less than 20 percent. Precipitation (liquid equivalent) mostly less than 2 mm. No snow accumulation expected.
On others (and mine) I see much less like:
Tonight: Dense overcast. Low 68. Wind south-southwest near calm.
Control Panel–>FTP & Connections–>General FTP Functions tab.
Click ‘Choose the file’ find and select the plaintext.txt file
Under ‘Remote Directory to use’ fill in your directory and click SET. (I think /wwwroot/wxsimforecast should work for you.)
Choose the times you want to upload the plaintext.txt file. (I upload mine 5 minutes after I have WXSIM create the forecast.)
You should have something like the screen cap below.
Try NotePad, and save as .php, and choose All Files (not txt). You cannot create new PHP files in WordPad without an additional extension being appended (rtf?).
Tried making info.php in both notepad and word pad, and ftp’d them to my server. I can see it in the directory, but when I try to open it in IE, all I get is an error 404 - file not found.
Munrobaggins (Roger) kindly sent me a copy of his info.php file which I uploaded and tried, still with no luck. I am therefore left with the conclusion my server is not php enabled. This is a great pity, as I love the look of the forecast charts produced.
However, Brian Hamilton is also looking at incorporating a facility for WD to produce similar charts. While there are still one or two minor nits with this, it is working reasonably well, so I am sticking with WD’s version for now. I have set this to run and update thrice daily on my website and, all in all, am fairly pleased with the result.
I have purchased the WXSIM program altough have not received it yet. In preparation I have been trying the forecasts and of course have a question! If you look at this test site http://www.branfordfire.com/weather/simtest.php you will see that I have a “chance of cloudy”. Does this look normal since I don’t have the full data package yet? Or is there something wrong with my images etc?
I could be wrong but I thought he was talking about the 0% showing under the forecast condition and temp. Like there’s a 0% chance of Sunny. If so, firewall, that is the chance of precipitation not the chance of the condition.
