Ok, i’ve tried an i’ve tried !! but nothing, lets start from scratch…
(from the help file)
At the PC where the weather station is connected:
Click on “Setup” in the menu bar. Click on “Setup / FTP / Internet …”. Click on the tab labeled “TCP/IP Client/Server”. Click the button at the upper left side labeled “Server Enabled”. You may want to click the button labeled “Show indoor temp/hum on client”. Click OK.
DONE
At each PC where the weather data is to be viewed:
Install WD on the machine. Follow the procedures in QuickStart but choose a station type of “Stationless”. You do not need to select a Comm. port, nor do you have to enable FTP.
DONE
Click on “Setup” in the menu bar. Click on “Setup / FTP / Internet …”. Click on the tab labeled “TCP/IP Client/Server”. Click the button at the middle left side labeled “Client Enabled”. You may want to click the button labeled “Show indoor temp/hum on client”. Click OK.
DONE
But still doesn’t work, also i am running Zone Alarm Pro.
on the client, there seems to be values from 3 months ago, but not updating
Any suggestions ?
Cyclone
