Author Topic: Auto scale extra temp/hum graph is -146 to -134  (Read 3125 times)
Snifferdude
  • Guest
« on: May 06, 2003, 08:58:51 PM »
I have the Dallas 1-wire temp/hum sensor and if I RC graphs/dallas 1wire extra sensor graph and click on the sensor 1 tab this graph is correct for temp and hum.  I named the graph and both sensors.  In the auto scale graphs the graph for the extra temp/hum has hum plotted OK but the temp range on the left is -146 to -134.  Any help?  I have named them and saved/restated the program a bunch.
Kevin
Online Weather Display
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #1 on: May 07, 2003, 02:17:34 AM »
humm
strange...
have you assigend a name for that temperature sensor in the dallas 1 wire setup?
Snifferdude
  • Guest
« Reply #2 on: May 07, 2003, 08:56:58 AM »
Yes, I did name the Hum sensor.  Also, in the auto scales the bottom 4 graphs have the same -134 to -146 scale for temp.
Snifferdude
  • Guest
« Reply #3 on: May 08, 2003, 02:15:05 PM »
I installed WD on another computer and without setting anything checked the auto scale graphs and the 4 extra sensor graphs are the same way, the left side scale goes from -134 to -146.  Does this sound like I don't have WD setup correctly to see the temp sensor part of the AAG temp/hum sensor?
Kevin
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #4 on: May 08, 2003, 07:09:59 PM »
which graphs again are doing this>?
email me your wdisplay.ini file from c:\windows or c:\winnt
and
the data file
month52003.inf
and
the registry entry
wdisplayftp.ini
see
http://www.weather-display.com/exportregistry.html
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #5 on: May 11, 2003, 06:47:13 PM »
i think i know....
its plotting the humidity only, and so the temperature scale should not be visible
but the dallas 1 wire humidity sensor has built in temperature, so i should/could plot that as well
but first i will blank out the temperature scale
Snifferdude
  • Guest
« Reply #6 on: May 12, 2003, 10:36:28 AM »
9.76a now has the temp working on extra graph #3 and the hum is on the extra graph.  I found that when you set the name for extra graph #3 is does not save it.  So, any way to get both the temp and hum working on the extra graph together?  Any way to be able to have a graph title on the top on each of the graphs on the auto scale graphs?  I am uploading the graphs to a web site and than would like to have on another web page a link to just the graph jpg so it displays alone, so a graph title in the jpg would be nice, but not needed if it is alot of work.
Thanks again Brian for all your help and fast response!
Kevin
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #7 on: May 12, 2003, 08:59:06 PM »
i have fixed the hum # 3 name now (reset it)
in a new 9.76a, ready now, and now you can set the title name for each graph as well too
Snifferdude
  • Guest
« Reply #8 on: May 15, 2003, 04:55:17 PM »
Thanks for the graph names!  The extra graph # 3 name does not save and now the outdoor temp/hum from the WM918 is plotted on extra graph #3 and it is plotted on the second graph down from the top.  The extra graph #1 still only has hum plotted on it. Can you get the temp/hum from the extra temp/hum sensor to plot together on one of the extra graphs?  I now have an extra temp only  1 wire sensor and it plots on the extra graph # 2 just fine.
Kevin
