How to upload timestamped video all day
How do I upload the timestamped videoallday (yyyymmdddayvideo.wmv) ?
Se attached screen-dump of my moviemaker.
The wmv files is produced every night at 23.45 and is saved in c:\Program Files\Wdisplay\alldayvideo - but it is not uploaded to my website.
Where do I specify that?
Running WD 10.36x build 09.
My datestamped wmv file is still not uploaded. Its created every night at about 23.47.
Se screen-dump (dissapeared from my last post)
ok, i see my mistake
i added the files to upload
but then deleted those entries a bit further down in the code again
use this new version:
http://www.weather-display.com/downloadfiles/moviemaker.zip
Hi Windy
Thanks - i will try the update tonight. Is it possible to change the upload directory where the file is uploaded?
Hi Brian, does this have anything to do with with the allday video not created every hour? http://discourse.weather-watch.com/t/22376
Peter
Heck, how do you get WD to create the alldayvideo for 24 hours at all? Mine only creates it for sunrise to sunset. I have “night time also” checked on create timestamped files, and the files are created, but WD doesn’t create the alldayvideo unless I manually override the times and click create all day video.
that last poster, it would help if you could provide information about which versions you are using, if you have WD set to control movie maker, or using wdwebcamcapture, etc
WD 10.36v. wdwebcamcapture is generating the alldayvideos, but I’m getting my source image via HTTP Download. The images get labeled.
i think you will find that problem is fixed in a more recent update of wdwebcamcapture.exe
as long as you have tickd , let me override the times
Hi Windy
Is it possible to decide where the yyyymmddvideo.wmv is uploaded to the webpage? (different folder that default)
not that moment
pinkpanther, i am running the latest wdwebcamcapture and moviemaker at the moment
and my video last hour is updating OK
see:
http://www.weather-display.com/windy/gb/lasthourvideo.htm
out now, have to take the 4 year old to preschool
Hi Windy
Thats ok - thanks for your very quick reply.
Have a nice day
Ok Brian, here is what happened after the update to 1036x 09, everything was running ok, I’m not using webcamcapture (IP camera) movie maker was working ok and uploading every hour(using the videolastday every hour) . After the update for some reason it was not making the movie at all, in the moviemakerlog I was getting the following
Deleting file C:\wdisplay\alldayvideo\2358jpgwebcam.jpg
Deleting file C:\wdisplay\alldayvideo\2359jpgwebcam.jpg
Starting to check for copying file nows to alldayvideo folder
Jpeg option File to copy C:\Inetpub\ftproot\mobotix[color=red]0600 [/color]-> C:\wdisplay\alldayvideo\0600jpgwebcam.jpg
File date =12/30/99 now date 12/13/06
Jpeg option File to copy C:\Inetpub\ftproot\mobotix\0601 → C:\wdisplay\alldayvideo\0601jpgwebcam.jpg
Jpeg option File to copy C:\Inetpub\ftproot\mobotix\0602 → C:\wdisplay\alldayvideo\0602jpgwebcam.jpg
time stamp without file name like 0601webcamimage.jpg(the file was made ok in the C:\Inetpub\ftproot\mobotix\0601webcamimage.jpg) so no files copied the alldayvideo, so no movie was made. I’ve tried just about everything but no luck. So today I upgraded to the new version 1036x 11 and still the same. Then I thought why not try to run webcamcapture and see what happens, after running webcam and just checking the settings they looked ok turned the main switch on and off and exit the program. After that run the moviemaker from WD and all worked fine. To me looks like there is setting in the webcamcapture that is missing from the WD control or something is not registering.
Anyway my problem is solved at the moment.
Thank you.
Peter
Hi Windy
I downloaded your update of moviemaker - the datestamped wmv file was not produced and uploded last night at aprox 23.47.
I will see what happens tonight.
Hi pink panther
the missing setting looks to be to use the jpeg time stamped file i think
i will check on that…
so, though, is it working again by going back to having wd control movie maker?
WD was controlling the moviemaker before too, the moviemaker was running on times ok but no movie files were made, due to the missing or wrong file name and the time stamped files were produced. What I have done now is I kept a backup of the registry now and if it happens again I will check the registry to see what has changed.
Thank you
Peter
Hi Brian
Last night 20061213dayvideo.wmv was created at 23.47 - but it was NOT uploded to my website.
The videolastnight.wmv was uploaded at 23.48 but not the datestamped file.
Im running WD 10.36 build 12
Last night the datestamped wmv files was created but not uploaded.
Tonight it was not created - here is the log in moviemaker:
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2229webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2229jpgwebcam.jpg
File date =12/30/99 now date 12/14/06
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2230webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2230jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2231webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2231jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2232webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2232jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2233webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2233jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2234webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2234jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2235webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2235jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2236webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2236jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2237webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2237jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2238webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2238jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2239webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2239jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2240webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2240jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2241webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2241jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2242webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2242jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2243webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2243jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2244webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2244jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2245webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2245jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2246webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2246jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2247webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2247jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2248webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2248jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2249webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2249jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2250webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2250jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2251webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2251jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2252webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2252jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2253webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2253jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2254webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2254jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2255webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2255jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2256webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2256jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2257webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2257jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2258webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2258jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2259webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2259jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2300webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2300jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2301webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2301jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2302webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2302jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2303webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2303jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2304webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2304jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2305webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2305jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2306webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2306jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2307webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2307jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2308webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2308jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2309webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2309jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2310webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2310jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2311webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2311jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2312webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2312jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2313webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2313jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2314webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2314jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2315webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2315jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2316webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2316jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2317webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2317jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2318webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2318jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2319webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2319jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2320webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2320jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2321webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2321jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2322webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2322jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2323webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2323jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2324webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2324jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2325webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2325jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2326webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2326jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2327webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2327jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2328webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2328jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2329webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2329jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2330webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2330jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2331webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2331jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2332webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2332jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2333webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2333jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2334webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2334jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2335webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2335jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2336webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2336jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2337webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2337jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2338webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2338jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2339webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2339jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2340webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2340jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2341webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2341jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2342webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2342jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2343webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2343jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2344webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2344jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2345webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2345jpgwebcam.jpg
Starting movie creation now
[INFO] end of device discovery
ERROR: Access violation at address 7C918FEA in module ‘ntdll.dll’. Write of address 11CE525F at time/date 23:45:59 12/14/06
some error with a windows dll file
maybe a resource issue…
Last night the datestamped file (20061512dayvideo.wmv) was created without any problems, but its still not uploaded to my website.
Im running WD 10.36x build 15.
