How do I upload the timestamped videoallday (yyyymmdddayvideo.wmv) ?
Se attached screen-dump of my moviemaker.
The wmv files is produced every night at 23.45 and is saved in c:\Program Files\Wdisplay\alldayvideo - but it is not uploaded to my website.
Where do I specify that?
Heck, how do you get WD to create the alldayvideo for 24 hours at all? Mine only creates it for sunrise to sunset. I have “night time also” checked on create timestamped files, and the files are created, but WD doesn’t create the alldayvideo unless I manually override the times and click create all day video.
that last poster, it would help if you could provide information about which versions you are using, if you have WD set to control movie maker, or using wdwebcamcapture, etc
Ok Brian, here is what happened after the update to 1036x 09, everything was running ok, I’m not using webcamcapture (IP camera) movie maker was working ok and uploading every hour(using the videolastday every hour) . After the update for some reason it was not making the movie at all, in the moviemakerlog I was getting the following
Deleting file C:\wdisplay\alldayvideo\2358jpgwebcam.jpg
Deleting file C:\wdisplay\alldayvideo\2359jpgwebcam.jpg
Starting to check for copying file nows to alldayvideo folder
Jpeg option File to copy C:\Inetpub\ftproot\mobotix[color=red]0600 [/color]-> C:\wdisplay\alldayvideo\0600jpgwebcam.jpg
File date =12/30/99 now date 12/13/06
Jpeg option File to copy C:\Inetpub\ftproot\mobotix\0601 → C:\wdisplay\alldayvideo\0601jpgwebcam.jpg
Jpeg option File to copy C:\Inetpub\ftproot\mobotix\0602 → C:\wdisplay\alldayvideo\0602jpgwebcam.jpg
time stamp without file name like 0601webcamimage.jpg(the file was made ok in the C:\Inetpub\ftproot\mobotix\0601webcamimage.jpg) so no files copied the alldayvideo, so no movie was made. I’ve tried just about everything but no luck. So today I upgraded to the new version 1036x 11 and still the same. Then I thought why not try to run webcamcapture and see what happens, after running webcam and just checking the settings they looked ok turned the main switch on and off and exit the program. After that run the moviemaker from WD and all worked fine. To me looks like there is setting in the webcamcapture that is missing from the WD control or something is not registering.
Anyway my problem is solved at the moment.
Thank you.
Peter
Hi pink panther
the missing setting looks to be to use the jpeg time stamped file i think
i will check on that…
so, though, is it working again by going back to having wd control movie maker?
WD was controlling the moviemaker before too, the moviemaker was running on times ok but no movie files were made, due to the missing or wrong file name and the time stamped files were produced. What I have done now is I kept a backup of the registry now and if it happens again I will check the registry to see what has changed.
Thank you
Peter
Last night the datestamped wmv files was created but not uploaded.
Tonight it was not created - here is the log in moviemaker:
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2229webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2229jpgwebcam.jpg
File date =12/30/99 now date 12/14/06
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2230webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2230jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2231webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2231jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2232webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2232jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2233webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2233jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2234webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2234jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2235webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2235jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2236webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2236jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2237webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2237jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2238webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2238jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2239webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2239jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2240webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2240jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2241webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2241jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2242webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2242jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2243webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2243jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2244webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2244jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2245webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2245jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2246webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2246jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2247webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2247jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2248webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2248jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2249webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2249jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2250webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2250jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2251webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2251jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2252webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2252jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2253webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2253jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2254webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2254jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2255webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2255jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2256webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2256jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2257webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2257jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2258webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2258jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2259webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2259jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2300webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2300jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2301webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2301jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2302webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2302jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2303webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2303jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2304webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2304jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2305webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2305jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2306webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2306jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2307webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2307jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2308webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2308jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2309webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2309jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2310webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2310jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2311webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2311jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2312webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2312jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2313webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2313jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2314webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2314jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2315webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2315jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2316webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2316jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2317webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2317jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2318webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2318jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2319webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2319jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2320webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2320jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2321webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2321jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2322webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2322jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2323webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2323jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2324webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2324jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2325webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2325jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2326webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2326jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2327webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2327jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2328webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2328jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2329webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2329jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2330webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2330jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2331webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2331jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2332webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2332jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2333webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2333jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2334webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2334jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2335webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2335jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2336webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2336jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2337webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2337jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2338webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2338jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2339webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2339jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2340webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2340jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2341webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2341jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2342webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2342jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2343webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2343jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2344webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2344jpgwebcam.jpg
Jpeg option File to copy C:\Programmer\Wdisplay\webcam\2345webcamimage.jpg → C:\Programmer\Wdisplay\alldayvideo\2345jpgwebcam.jpg
Starting movie creation now
[INFO] end of device discovery
ERROR: Access violation at address 7C918FEA in module ‘ntdll.dll’. Write of address 11CE525F at time/date 23:45:59 12/14/06
