Author Topic: Two silly questions!  (Read 4999 times)
Offline Andy
  • Nomansland Weather. Wiltshire, UK
  • Nomansland, Salisbury, Wiltshire, UK
    • http://www.workandplay.org.uk
« on: April 08, 2003, 07:40:21 AM »
Question 1. - ALL TIME RECORDS What is the difference between "Record Low Temperature" and "Coldest Night"? My Record Low Temperature shows -3C on the 8th April at 05.53, where my Coldest Night shows -6.4C 12th Jan at 5.59. Surely the latter would be the record temperature. There is a similar instance with the warmest day and the record high temperature.
Please could someone explain and clarify
Question 2. Files generated for 24 hour readings as a .gif. e.g. 242003.gif for 2nd April 2003. How do I set up WD to create these files? Have I missed something. I have explored all the files within my PC and they appear not to be generated.
Any help would be grateful
Cheers,
Andy
Davis VP1 - 6310C, Microsoft XP pro with 1Gb memory, Processor 1.4GHz. Website - www.workandplay.org.uk. Email - [email protected]
Offline grhughes
  • Huntsville,Alabama, USA
    • RuppWorld
Andy
« Reply #1 on: April 08, 2003, 11:31:09 AM »
The Warmest Day /Night and Coldest Day /Night needs to be reworked.  The information is reversed.
As far as the files being generated.  Do you leave your PC running all the time.  I thought these got created at the midnight rollover.
-Rupp
WinXP
Davis VP
Offline Andy
« Reply #2 on: April 08, 2003, 02:34:21 PM »
Yes, my PC is left on with WD running 24/7. That is why I am not sure.
Thanks for letting me know about the All Time Records. Obviously I gather Brian is aware of this problem. I gather he will correct this with all his many other jobs he does with WD.
Cheers,
Andy
Offline grhughes
    • RuppWorld
Well NO actually
« Reply #3 on: April 08, 2003, 03:54:18 PM »
I think he and others believe the Warmest Day /Night and Coldest Day /Night is being reported correctly?  I just can't figure out how the nights average would ever be warmer than the days average (on average) ?  Maybe someone can enlighten me again.
-Rupp
WinXP
Davis VP
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #4 on: April 08, 2003, 05:23:42 PM »
those files andy are only renamed on your web server at the time of ftp upload (i.e at the daily averages/extreme upload)
other Q:
that should not be the case
and, i am willing to change the way these numbers are calculated, instead of being :
the coldest or warmest temperature from 6pm or 6am,(average, but calculated on the fly) to calculating the 12 hour average only once the 12 hour average period has ended (and the the time of occurence is not needed, just the day)
Offline administrator
  • Administrator
  • Blackpool, UK
    • Weather-Watch.com
« Reply #5 on: April 08, 2003, 06:51:01 PM »
Quote from: windy
I think I've said this before, but this calculation sounds good to me. Would it be worth adding warmest/coldest 24 hour averages (00:00-23:59) at the same time?
Chris
Weather Forum Administrator
Offline Andy
« Reply #6 on: April 08, 2003, 07:11:28 PM »
Thanks Brian for getting back so prompt. That would be great if you could change this, as I am sure as it is with others, it could cause a lot of confusion. I assume someone else must have picked this up in the past, or am I the first.
Thanks also for the other part regarding the 24hr records. I shall investigate further, but no doubt, I will expect need more assistance and clarification to set up.
Cheers,
Andy
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #7 on: April 08, 2003, 07:43:42 PM »
those graph names are uploaded atuo at the averages/extreme upload times, if you have that option ticked, under web upload times.....(upload date stamped daily graph files), but you wwill need lots of web server space...
Offline Andy
« Reply #8 on: April 08, 2003, 07:46:38 PM »
I have 10Mb of web server space, is that sufficient
Cheers,
Andy
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #9 on: April 08, 2003, 07:54:38 PM »
well, the daily graph files are small in size, but over time it starts to eat into the total web server sapce, but that might take 5 years
Offline Andy
« Reply #10 on: April 08, 2003, 07:56:29 PM »
I can only try it out, and as my site gets bigger, I can only go and increase it's capacity
Cheers,
Andy
