Author Topic: Weather station on a alpine downhill skiplace.  (Read 2455 times)
Offline zapp
« on: October 30, 2006, 03:48:18 PM »
Hi, i have got an requst of setting up an weather station in an alpine downhill skiplace.
They want temperature and wind readings both at the bottom and on the top of the course.
At the bottom there's a cafeteria with dsl/broadband. at the top there's a power outlet, gsm mobile coverage, (maybe wlan coverage)
The top location is not visible from the bottom. in distance it is about 2km
So how can i do this?
I know Davis VP2 has long range repeaters, with this one can i place the repeater in line of sight of both places, but somehow Davis does not support 2 aneometers, or do they?
Lacrosse has limited wireless range and no extra aneometer possibilty.
So maybe i should go for to two weather stations, the one on top is a VP2 transmitting via a long range repeater down to the bottom, the other one located at the bottom can be a cheap lacrosse.
Is this the best way to go? or have i got this totaly wrong? :)
Thanks in advance,  i appreciate any feedback.
Offline talbert1952
  • Tobaccoville, North Carolina USA
    • Tobaccoville Weather, Tobaccoville, NC USA
Re: Weather station on a alpine downhill skiplace.
« Reply #1 on: October 30, 2006, 04:09:28 PM »
A Davis console can only display one ISS/anemometer at a time. However, you can buy 2 Davis stations and set them to different channels so they don't interfere with each other. One console displays the top station and the other console displays the bottom station.
Tom
W4SNA
http://tobaccovilleweather.com/
Davis wireless VP2 with fan aspirated radiation shield, WMR968, Boltek Stormtracker PCI
Weatherlink, VWS, Image Salsa, Lightning/2000
Offline niko
  • syzygy
  • Global Moderator
  • Northern California, U.S.A.
« Reply #2 on: October 30, 2006, 04:42:08 PM »
Be aware that "channel" in Davisspeak means a different identifier sent with the data, not a different radio freqency. With the frequency hopping of the VP2 then it should work out OK, but if you can install it I would think about (cheaper) a wired VP2 for the lower location, and just use wireless for the top.  IMHO you would be asking for trouble using a "cheap lacrosse" in that environment.
Offline looney2ns
  • Fearless Weather Dog-Loves to watch Lightning.
  • Near Evansville Indiana USA
    • Newburgh Weather
« Reply #3 on: October 31, 2006, 12:34:29 AM »
I would think you would want something with heated anemometers.
Sounds like a location begging for true professional equipment.
Offline niko
  • syzygy
  • Global Moderator
« Reply #4 on: October 31, 2006, 12:39:02 AM »
Good point, a job for vaisala!
Offline dendrite
  • Northfield, NH
    • Eastern US Weather Forums
« Reply #5 on: November 04, 2006, 01:35:36 PM »
Yup...heated sonic anemometer.
Buy one for all of us too.  8)
Offline administrator
  • Administrator
  • Blackpool, UK
    • Weather-Watch.com
« Reply #6 on: November 05, 2006, 08:06:22 AM »
I thought the Vaisala was wired so it probably won't help in this case. It would be a good cold weather device though
Chris
Weather Forum Administrator
