(problem only happens to people that at some stage have clicked on save in the main screen customisation)
what you need to do is shift the temperature scale to where the indoor/extra temperature scale is (i.e hard up against the graph) and shift the indoor temperature/extra scale to where the outdoor temperature was
via the main screen customise: setup, advanced/misc, main screen, tick to enable customisation, then use shift and mouse move over the scales to move them, then go back and click on save in that advanced/misc, main screen customise
the scales have been flipped 180o to allow the showing of the pointers (option you can enable in the graph setup)
and they need to swapped positions to see those pointers and the scale numbers (its OK if no customisation of the main screen had been saved)
