Author Topic: Error Reading A/D result  (Read 4948 times)
Offline JeffCharger
  • Ontario, Canada
« on: April 05, 2003, 12:28:58 PM »
I am periodically getting an error with my 1-wire results.  The error causes my temps to flatline.  The error reads "Error Reading A/D Result (-12)!".  I assume that the A/D refers to the analog/digital conversion being done by the DS9097 unit.  A restart of WD seems to cure.
Any clue what is happening?
weather display, HomeSeer, AAG V3, LaCrosse Rain Gauge
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #1 on: April 07, 2003, 09:20:09 AM »
the A/d is also used for wind direction and humidity as well
it should recover , but is it not?
sounds like yoru 1 wire setup need improving if you are getting these errors (check connections, use CAT 5 cable as much as possible, etc)
Offline JeffCharger
  • Ontario, Canada
my wind and direction were fine
« Reply #2 on: April 07, 2003, 09:53:27 AM »
Windy, my wind and direction were fine.  I received the error message twice (viewing in the 1-W setup).  They didn't seem to recover but a restart of the program found them fine.  Why would it be ok for wind and direction and not for temp?
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #3 on: April 07, 2003, 09:56:17 AM »
do you have any humidity sensors, barometer sensors, solar sensors?
they are all the A/D type of sensor.....]
bed time here
Offline JeffCharger
  • Ontario, Canada
no humidity sensors yet
« Reply #4 on: April 07, 2003, 10:02:46 AM »
I don't have humidity or barometric as yet.....only an AAG station and a number of  temp sensors.
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #5 on: April 07, 2003, 10:15:54 AM »
a vers 3 aag station uses a a/d converter for wind direction.....
Offline JeffCharger
  • Ontario, Canada
so why would some work
« Reply #6 on: April 07, 2003, 10:31:01 AM »
and not others?
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #7 on: April 07, 2003, 04:59:36 PM »
no, the vers 1 does not...
so its the wind direction a/d converter that will be throwing up the error.....which might be due to low voltage on the 1 wire network
Offline Leo
  • Wellington,NZ.
    • http://homepages.paradise.net.nz/lfduflou/Silverstreamweather.htm
« Reply #8 on: April 07, 2003, 08:59:03 PM »
I get a similar error if I have more than 3 temp sensors,solar,lightning
on the same port adapter.
Also happens if I have a long run using ordinary telephone cable instead of using cat 5 cable.
Never able to pinpoint the reason but I suspect that voltage drop was the cause.
 8O  :o
XP ProSP2 AMD XP2600+ 1GB ram IE7 Beta3 Cable Modem Z/A Pro
http://www.kiwiweather.co.nz/whitbyweather/
XP ProSP2 AMD XP3200+ 1GB ram IE7 Beta3  DSL Z/A Pro
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #9 on: April 07, 2003, 09:08:43 PM »
the solar sensor is a  1 wire A/D  :)
the A/D is most sensitive to not enough voltage on the 1 wire network
