Author Topic: WD not saving setting?  (Read 1586 times)
Offline r.furborough
  • Norfolk, VA
    • Environmental Conditions for Lynnhaven, VA
« on: March 18, 2003, 03:36:27 PM »
Brian,
I am begining to think that WD is not saving, even when exiting correctly using menu: 'Exit / Save and exit'
I suspect this because when I exit, I loose the rainfal data for the current day, it zero's like it would for the midnight reset.
The next pointer relates to the setting of colors.  You may recall in a recent thread I noted that I couldn't changed the data box color back to white after changing it using the color setup options.  I found that I had the setting for setting the  data box color to the background color.  I changed this to 'no', but it is not saving this setting as when I exit WD to update the program and the restart, the setting the  data box color to the background color is back to 'yes'
Bob
Stand-By I am setting up a complete new system....
