Author Topic: VPlive Stalled  (Read 2401 times)
Offline TNETWeather
  • Kevin Reed (KrelvinAZ)
  • Gremlins are at work...
  • Mesa, AZ
VPlive Stalled
« on: September 03, 2006, 09:13:10 PM »
Hmmm... didn't notice it earlier but VPLive apparently stalled out this morning...
The Log.txt file has:
9/3/2006 00:00:00:557 Warning      - Cannot find WeatherLink application file
9/3/2006 08:00:00:830 Warning      - Cannot find WeatherLink application file
And on the VPlive console near the bottom in red it says...
8 Hours, 39mis since last Data.
VirtualVP doesn't show any issues and is still running.
I see under settings that even though I didn't setup weatherlink with it, it was still set to use a sched freq of 8 hours.  I changed it to Never which most likely should be the default.
I hit the connect tab on the top and it came back online.
Offline SoftWx
  • Moderator
    • SoftWx
Re: VPlive Stalled
« Reply #1 on: September 03, 2006, 09:19:42 PM »
There is a log.txt file in the VPLive folder, and one in the VirtualVP folder. If you send me those two files (support at softwx.com) I may be able to find an explanation or cause.
Steve
Offline TNETWeather
  • Mesa, AZ
Re: VPlive Stalled
« Reply #2 on: September 03, 2006, 09:29:11 PM »
sent
