Need help in understanding why my cwop is not working correctly.
http://www.findu.com/cgi-bin/wxpage.cgi?CW2392
Worked fine not to long ago.
Thanks in advance
Mike
Thanks in advance
Mike
need more info
e.g the ftp log file, copy and paste that here, after a CWOP update
also, what is the lat/long you have setup there?
It appears that your connecting fine, but the data your sending is not changing…
CW2392>APRS,TCPXX*,qAX,T2WXCWOP:@200410z4135.25N/07245.87W_158/000g002t071r020p024P000b10125h88.WD 60
Morning…I’ve attached the ftp log. There is is an error happening in the upload process, not sure why.
ftplog.txt (105 KB)
we need the ftplogfull.txt file
Mike, can you go to control panel → cwop and hit the test button, then grab the contents of your ftplogfull…we need to see the attempt to send cwop data…should look similar to this:
Aprs data sending now..... APRS Connecting to: arizona.aprs2.net Aprs connected sending pass command user CW1789 pass -1 vers wx-display 10.35u 31 Sending the aprs data now APRS data send: CW1789>APRS,TCPIP*:@262255z3917.30N/12120.17W_245/006g013t084r000p000P000b10101h33.WD 31 Disconnecting from the aprs server now APRS disconnected
Here’s the file…
list of files uploaded*
Start Time/date:9:49:01 AM 8/27/2006
ctz002.txt
ctz002.txt
Permanent connection selected
Checking for what else to do…
there are 1 more things to do
Aprs data sending now…
Aprs connected
user CW2392 pass -1 vers wx-display 10.35r 60
APRS data send:
CW2392>APRS,TCPIP*:@200410z4135.25N/07245.87W_158/000g002t071r020p024P0
00b10125h88.WD 60
APRS disconnected
Finshed email agenda
Finished email agenda, no ftp items to do…
Your connecting to the site ok, the problem is your data is not changing…something in your WD setup is not updating the CWOP data with your current conditions. You could try disabling CWOP, exit WD, re-start WD, then re-enable CWOP and see if that gets it going again, or maybe Brian has seen this problem before and knows what causes it.
I’ll give it a shot…thanks for looking into it.
make sure you do not have set to share the data files in the advanced/misc setup
i.e, is the data on the graph in WD updating?
Graphing…weather underground data are working…I’ve stopped the CWOP program, shut WD down then restarted…to no avail…any other ideas?
also check the lat/long is set correct in the cwop setup
also check your time zone is set correct in the windows regional settings, too
Anything strange happen around the 20th with your system?
Mike,
http://discourse.weather-watch.com/t/10889 is the FAQ for installing a second WD on your computer without messing with your current install. It is useful for tracking down configuration and hardware problems. Just setup WD with the bare minimum for connecting to your sensor, ftp, and cwop details. Then see if it is successful at uploading cwop.
Hello all,
I did notice that my lat and long did not match what was on the mesowest map. According to the map my location should be
LATITUDE: 41.5875
LONGITUDE: -72.7645
ELEVATION: 180 ft
MNET: APRSWXNET/CWOP
However when I go to the cwop set up in wd it’s showing as 4158.25N and 07259.45W…Please note that the latitude does not match nor can I manually change it. It reverst back to 4185.25n
Would that explain why the data being sent never changes?
Could or should I do a system restore to see if that helps? Pehaps a file of some sort was deleted during a disk clean up I recently performed.
Mike
07259.45W..
where do you live?
if east of London, then that should be EAST number (E on the end)
i.e you should have, in WD, in the CWOP setup
07259.45E
instead
NAME: CW2392 Berlin LATITUDE: 41.5875 LONGITUDE: -72.7645
the longitude means you are east of London (GMT), Berlin…yes?
[quote]Registered Location
Latitude: 41
What program did you use for that? Having a hard time making heads or tails of your txt file here…lot of strange characters in it make it hard to read.
(I used notepad to open the file, then highlighted the text and copied into the message I was typing above…)
edit: I see some other folks have looked at the file now, was anyone able to read the file without all the extra characters?
