Hi Everybody,
WXSIM 11.1 is now up at www.wxsim.com. It now has WeatherLink as well as Weather Display support for the forecast/actual comparisons (though the WD version is a bit more direct, as the WL option requires first importing data through WXSIMATE). The comparisons can now be saved as a .csv spreadsheet file, and you can view a list of the forecasts you’ve combined for comparison. I think the comparison routine is now robust enough to get really good data on how WXSIM is doing. I was able to quickly combine a few dozen forecasts among the 200+ I’d saved over the past year.
I also improved the saved forecast .csv files, making the column headings left-justified for better visibility and including the secondary weather description (I’d meant to earlier, but had left out a variable declaration - now fixed).
(As for that price increase, I just went up about 9 dollars on WXSIM and 4 on WXSIMATE).
Thanks!
Tom
