Author Topic: Console diagnostics no response warning msg  (Read 2898 times)
Offline Ravenstar
  • Verona, PA Near Pittsburgh USA
    • Verona, PA Weather
« on: August 04, 2006, 10:17:11 PM »
Is this anything to be concerned about Steve? (VPLive)
« Last Edit: August 04, 2006, 10:27:58 PM by Ravenstar »
Offline SoftWx
  • Moderator
    • SoftWx
Re: Console diagnostics no response warning msg
« Reply #1 on: August 04, 2006, 10:41:44 PM »
It depends. It means that the console failed to respond to a command after VPLive tried several times to send the command. Sometimes this just happens. For example, at midnight every night, the console stops responding for several seconds while it processes end of day stuff. If the console begins responding again, then you can ignore it. If it happens frequently, or if VPLive continues to get no response and then has to give up, then there is a problem. You can look at the activity log and get an idea how frequently and for how long this is happening.
Steve
