Thanks for your reply - i have tried to translate the error from Danish to English.
And yes i have installed the demo-versions of both programs. And the error did happen first time i runned the program.
By the way - what about my question - could that have something to do with the error?
When I try to import data from WD - i change the local station to WD and type the path to WD logfiles in “local station data directory” and press “Import Data”.
Then something happens - because my CPU works very hard. But i cant see any data is stored in the vwsim folder. If I close WXSIMATE and starts WXSIM and import local data - it says “File localdat.txt not found. This feuture requires output from the WXSIMATE program”.
Translation from Danish to English:
First the dialog box:
[color=red]There was an non-runned exception in the program. If you click continue the program will ignore the error and try to contiunue. If you click on end, the program will be closed down at once.
The information about the currency seperator, that are chosen in the NumberFormatInfo are ambiguous (equivoca) by parsing[/color].
Then the information in the detail section of the dialogbox:
[color=red]Look at the end of this information, if you want detail about how you start JIT error finding instead of this dialogbox.
************** Exceptiontext **************
System.ArgumentException: The information about currencyseperator, that is specified in NumberFormatInfo, are ambiguous (equivoca) by parsing.
at Microsoft.VisualBasic.CompilerServices.DoubleType.Parse(String Value, NumberFormatInfo NumberFormat)
at Microsoft.VisualBasic.CompilerServices.IntegerType.FromString(String Value)
at wxsimate.Form1.Form1_Load(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded assemblies **************
mscorlib
Assemblyversion: 1.0.5000.0
Win32-version: 1.1.4322.2032
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
wxsimate
Assemblyversion: 1.0.2396.28161
Win32-version: 1.0.2396.28161
CodeBase: file:///C:/wxsim/wxsimate.exe
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
Assemblyversion: 7.0.5000.0
Win32-version: 7.10.6001.4
CodeBase: file:///c:/windows/assembly/gac/microsoft.visualbasic/7.0.5000.0__b03f5f7f11d50a3a/microsoft.visualbasic.dll
mscorlib.resources
Win32-version: 1.1.4322.573
CodeBase: file:///c:/windows/assembly/gac/mscorlib.resources/1.0.5000.0_da_b77a5c561934e089/mscorlib.resources.dll
System.Windows.Forms.resources
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms.resources/1.0.5000.0_da_b77a5c561934e089/system.windows.forms.resources.dll
************** JIT-error finding **************
If you want to activate JIT-error finding, then you have to set the jitDebugging value
in the section system.windows.forms in the configuration file
for the program or your computer.
The program shoud also be compiles with errorfinding activiated.
Excampel:
When JIT-error finding are activated, will all non-runned exceptions be sent to the JIT-error finding function, that will be registred on your computer,
instead of beeing runned in this dialogbox.[/color]
