I’m running WD10.35m with XP-Pro. After it’s been running for a while, more and more copies of wdxmlwarning.exe start. Right now I can see five copies in the system tray (see attached photo). If I look at the task manager, I also see five copies and all of them are using up CPU cycles until the processor is maxed out at 100%.
every 10 minutes, if set to, they are run…
but there must be a problem with the info , and maybe some error or loop is occuring , and they are getting stuck and not exiting
what is the zone, report you have set to use, etc
Brian,
My zone is COZO39. In the past 24 hours, it hasn’t opened additional instances, but we haven’t had many warnings either. I’ll send you a log file from a recent warning download by email. And I’ll post again in a few days when I return from my travels and let you know if the problem as come back since I rebooted.
David
