Author Topic: Synchronization to WD will hang  (Read 3952 times)
Offline ulwivst
« on: July 04, 2006, 06:01:05 PM »
Hi, I have just bought a VP2 Plus and are setting up the environment. I'm thinking of using VirtualVP and WD/WD Live in an old laptop on a home network. From a desktop I will use TCP/IP to connect to VirtualVP.
On the laptop it works fine live but at startup of WD the screen Datalogger Extraction will hang. I have to click abort and then the connection works fine. I have tested WeatherLink in the same way and it works fine. It downloads the archived data. Are there setting in WD I have missed for using with VirtualVP?
Offline ulwivst
Re: Synchronization to WD will hang
« Reply #1 on: July 05, 2006, 07:26:44 PM »
I have found asolution in WD Forum. There was time difference between console and PC (3 min).
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #2 on: July 05, 2006, 09:07:13 PM »
thats good news :)
Offline niko
  • syzygy
  • Global Moderator
  • Northern California, U.S.A.
« Reply #3 on: July 05, 2006, 11:39:53 PM »
How about adding a warning or something for VP time discrepancy?
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #4 on: July 06, 2006, 02:05:10 AM »
its more a problem with the data logger not being able to find the time to get the data from that WD requests...will happen say if the vp clock is too fast....so wd is just sitting there waiting (not really a hang)...
its possible i could get wd to check the time on the console before requesting for missed data, and then report if there is a big difference from the pc time////
