Author Topic: WUSIWUG editor....can not handle animated gif's  (Read 6545 times)
  • Davis VP2
  • New Zealand
    • Weather Display
« on: June 15, 2006, 09:47:24 PM »
i have discovered that the built in WUSIWUG editor in WD crashes WD when you got to select an animated gif image for an image to show on the web site....
(becuase the animated gif image is liked when in preview image mode...I have seen that before,...some compiler problem)
instead, just use, insert, html code
and then go, e.g,
<img src="gizmo.gif">
« Last Edit: March 14, 2007, 09:38:02 PM by administrator »
